    WiFi Setup
    wifi setup
    • hoddino
      hoddino last edited by
      Is it possible to enter WiFi SSID and WiFi Key without having to connect a keyboard?
      • ivwshane
        ivwshane last edited by
        I haven't found a way.   If you use a wired connection you could then connect via your smartphone and manually edit the config file and add your wifi info.
        • hoddino
          I got some help from the irc channel and the only way to do it right now is to SSH into the machine and edit: /recalbox/share/system/recalbox.conf Remove the ; infront of wifi.ssid and wifi.key ## Activate wifi (0,1) wifi.enabled=1 ## Wifi SSID (string) wifi.ssid=your_wifi_here (spaces are ok) ## Wifi KEY (string) wifi.key=your key
