    Neogeo system acting weird in Dragonblaze 6.0
    neogeo acting weird dragonblaze 6.0
    • Alexander
      Alexander last edited by
      Hi, I'm using RPI3 with Dragonblaze 6.0 and neogeo system core set to fba_libreto
      My custom shader set in global.shaders in recalbox.conf (which works fine for all the other systems) is not being applied
      Besides none of the hotkey special commands (load or save state, reset, RA Menu...) are working except for "Hotkey + Start"
      This only happens in the neogeo system, and if I put those same neogeo roms in fba_libreto folder and play them via fba, everything works fine.
      I haven't added any special setting in recalbox.conf for the neogeo core.
      If this a bug, or is there anyone having the same problem?
      Thanks in advance
      100.6k
