    Error usb device descriptor
    GamePad/GPIO/USB encoder
    error usb
    • abismatico
      abismatico last edited by
      Hello! Good evening I have a problem with my USB ports. I do not detect any command just the keyboard
      This happened a few days ago and what I did was reinstall the system but the error persists
      Some data
      Recalbox version 4.0
      RasPberry 3
      Attached an image with the error that gives me the start
      https://i.ibb.co/mRhK0DN/Screenshot-2019-05-18-00-53-50-1.png
      • mattmame
        mattmame last edited by mattmame
        Hello, it seems to be a hardware problem. Try using a usb hub with external power
        Si vous avez aimé mon post ou s’il a pu vous aider, mettez moi une petite flèche vers le haut.
        abismatico 1 Reply Last reply Reply Quote 0
        • abismatico
          abismatico @mattmame last edited by
          @mattmame
          the keyboard works well, I must try a hub, the strange thing is that the keyboard works, the power supply changes it and I have the same problem
          mattmame 1 Reply Last reply Reply Quote 0
          • mattmame
            mattmame @abismatico last edited by
            @abismatico sometimes usb doesn’t give enough power for various device. Your keyboard may work and an other device not.
            Using a usb hub externally powered can help you
