    Best way to update from latest 4.0 to 6.0?
    Your recalbox
    update latest 4.0 6.0
    • Jonny0r
      Jonny0r last edited by
      Hello,
      perhaps somebody has an good idea, as due to all this changes its not possible to update from 4.0 to 6.0 and a fresh installation is needed.
      What is the best and easiest way to get all my old games working again, as it was a hard fight to scrap all the images and everything.
      How did you do it?
      Regards,
        Fresh install with new microsd.
        Backup roms bios saves only if use microsd only.
        Rename recalbox to recalbox.old if you use usbkey.
        Move only roms bios and saves
        Rescrap all emulators with skraper or Arrm.
        • Jonny0r
          Sounds pretty easy 🙂
          Rescraping is the only thing i really worry about, as i took their times all the pictures and stuff from my Hyperspin as the default scraper didnt work. It was not that much work as with HS itself but not that easy 🙂
          I bought yesterday a second card and will give it a try, thanks for your support 🙂
