    PC 98 how to change disk?
    Emulator Arcade/PC/Console
    • kelv
      kelv last edited by
      Hello
      Pls, Does anybody know how to change/swap disks in PC98?
      thx
      Raspberry Pi model: RPi 3b+
      Recalbox build : 7.0.1 DragonBlaze
      Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
      Overclocked: 1485 MHZ
      Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
        voljega Banned @kelv last edited by voljega
        @kelv Isn't there a menu on L1 or L2 ?
        EDIT : sorry made a mistake with X68000
        • nordicpower
          nordicpower last edited by nordicpower
          @voljega
          when you use L2 on your joystick, a menu called "Neko Project II kai" appears with a pointer, but mouse's emulation don't works....
          [EDIT] Mouse emulation is available in retroarch menu => Options / Joypad to Mouse Mapping "ON".
          When you want to change disk image, you can use FDD1 or FDD2 menu (inside FDD):
          text alternatif
          But the open file menu can see only /recalbox/share/bios/np2kai folder
          If you have a better solution... Put it in this forum
