    Problem adding PSX games
    roms trouble ne
    • ezrubiera
      ezrubiera last edited by
      Hi, I am having some troubles trying to add PSX games to the Rpi2 . I am trying to add these games (file format .bin in this case) via ethernet. I drag and drop in the roms/psx directory inside RecalboxOS. It starts calculating but few seconds later appears a message saying that there was an error. I could add 2 psx games (Castlevania and Medievil) but now it is not possible. Is there another way to add these games directly in the SD card? I have this problem with the PSX games so I think it is because they are big files (700MB more or less). Maybe its something related to my network but I don't know, I am not an expert with this things so if you can help I will appreciate it. Thanks in advance 🙂
      • ezrubiera
        I am using WinSCP and seems to work fine ^^
