    Sudo: command not found
    sudo
    • amzg
      amzg last edited by
      Does anyone know why this happens? and how to fix it ? Thanx </span>
        Recalbox is on root, so don't need sudo. But I can see, that you try to use "apt-get" command. Recalbox don't include package manager, so you can't install software directly on your recalbox. It is an OS, builded from scratch with buildroot, with only necessary stuff to run. It is thought as a firmware. So, if you want to add a software, you need to add a buildroot package, then build from scratch the OS.
        • amzg
          amzg last edited by
          OK!! thanx rockaddicted
