    Solved Scraping Issues With 6.0 Latest Release
    Your recalbox
    scraping 6.0 latest release
    4379
    • tdelios
      tdelios last edited by tdelios
      Fresh install and tried the scraping tool against roms of 6 different consoles (mame, nes, snes, psx, atari2600) using 'The GamesDB' and 'MAMEDB'. I tried both User Deciding Conflicts on/off
      'The GamesDB' didn't find any games at all and 'MAMEDB' looked like it was finding my mame games, but during the scraping process the information it was displaying on the screen for each mame game looked corrupted and the end result is that it didn't save any of the corrupted scraping it performed.
      I know the games in these 2 scraping sites are there because I have a backup copy from my 4.1 version.
      Can someone confirm if the scraping on the latest 6.0 is broken and if I use my backup gameslist and image folder on the 6.0 will work if I copy them over and not break anything?
        Hello @tdelios
        scrap broken and disabled.
        use extern srapper like skraper or other.
        tdelios 1 Reply Last reply Reply Quote 0
        • tdelios
          tdelios @acris last edited by tdelios
          @acris thx..
          can I use my backup gameslist and image folder from my 4.1 version?
          • sfccasa
            sfccasa last edited by
            Hello,
            Yes you can. They are the same
            Pi3 B Recalbox 18.xx.xx (celle avant la V6 quoi..🤣);Pi3 B+ Recalbox V6 et Mini Dell Optiplex 2046M (Nuc) Recalbox V6 64Bits
            Manette :
            Xbox 360 filaire, 8bitdo SF30 Bluetooth et PS4 Bluetooth
            • HapHzrd
              HapHzrd last edited by
              Thanks for this. I was having the same problem, and I thought I was doing something wrong.
              • Lee McNutt
                Lee McNutt last edited by
                If I use an external program to scrap how do I get the images to recalbox? I tried to drag and drop and nothing has worked.
                101.4k
