    Fresh Install Freezing / Unhandled Fault
    fresh freezing unhandled fault
    • garradam
      garradam last edited by
      Hello all, looking for some help because I am at a loss!
      I originally set up a system with Retropie but was having many issues with the system freezing, making it unusable. I ended up getting kicked out of the Emulation Station with the command prompt message:
      "Unhandled fault: alignment exception"
      I gave up and jumped ship to Recalbox. Using a new memory card, I booted a fresh install and after a minute or so of being idle at the main screen menu, the system froze and I got booted off to the same "Unhandled fault" message that I was getting with Retropie. I had done NO configuring at this point.
      My hardware is as follows:
      • Raspberry Pi Zero
      • Sandisk Ultra Micro SD HC 16gb
      • Official RP power adapter, 2.5amp
      • USB keyboard
      • USB SNES controller
      I have attempted this setup on 2 different Raspberry Pi Zeros and 2 different memory cards with the same result. ANY help or guidance would be appreciated!!
      100.7k
