    N64 exits when using Wii Classic Controller
    GamePad/GPIO/USB encoder
    exits wii classic
    • lhari84
      lhari84 last edited by lhari84
      Hi guys,
      I tried original Nintendo Wii remote + original Nintendo Classic controller connected to it.
      Seems to work fine so far with latest Recalbox stable and all emulators, but NOT the N64!
      When I run N64 with other controllers, it works fine too. But as soon I run an N64 game with Nintendo Wii remote + Classic controller connected, it immediately exits (crashes?!) afterwards.
      In another thread I found a hint:
      It’s written that L1+R1 buttons have to be mapped for N64 to work properly. In case of Nintendo Classic controller these buttons are recognized as axis instead of buttons. Maybe the N64 emulator doesn‘t like this??
      Unfortunately I found no way to recognize them as buttons. Even not trying the mapping again a few times, like it sometimes works with other controllers.
      Is there a way to change axis to buttons manually in config file? Or does anybody have another idea why N64 emu doesn‘t like the Wii Classic controller combination?
      Another thing:
      As Wii remote and the directly to it connected Classic controller are recognized as 2 independent controllers, the Classic controller is always recognized as controller 2 (Wii remote itself always is controller 1 by default!)
      This means when I run a game as single player, it‘s always controlled by Wii remote by default. Have to choose Classic controller as controller 1 in Recalbox configuration before running a game because of that. Any chance to make Recalbox ignore the Wii remote itself and making Classic controller automatically to default controller 1 this way?
      My config:
      • Pi 3B
      • Latest RB stable (July 2018)
      • CSR-based bluetooth dongle
      • Controller I‘m talking about (connected to Wii remote):
        https://en.m.wikipedia.org/wiki/Classic_Controller
      Thanks for your help!
      Pi 4:
      Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
      Pi Zero 2W:
      GPi Case 2W, Recalbox 9.0
      • lhari84
        Found a way to map L1/R1 as buttons instead of acis in the meanwhile. But problem with N64 persists, so it‘s not the reason 😞
        Any ideas?
        Pi 4:
        Pi Zero 2W:
        • lhari84
          This appears in es_launchstderr.log
          Traceback (most recent call last):
          File "/work/output/target/usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 227, in <module>
          exitcode = main(args)
          File "/work/output/target/usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 153, in main
          command = generators[system.config['emulator']].generate(system, args.rom, playersControllers)
          File "/usr/lib/python2.7/site-packages/configgen/generators/mupen/mupenGenerator.py", line 20, in generate
          mupenControllers.writeControllersConfig(playersControllers)
          File "/usr/lib/python2.7/site-packages/configgen/generators/mupen/mupenControllers.py", line 51, in writeControllersConfig
          config = defineControllerKeys(player)
          File "/usr/lib/python2.7/site-packages/configgen/generators/mupen/mupenControllers.py", line 92, in defineControllerKeys
          config['Z Trig'] = setControllerLine(mupenmapping, controller.inputs['x'], "Z Trig")
          KeyError: 'x'
          ... I have no idea what to do ...
          Pi 4:
          Pi Zero 2W:
