    Recalbox, can I add roms to the sd card/usb .
    Your recalbox
    recalbox roms cardusb
    • bizmoan
      bizmoan last edited by
      Can I add roms to the sd card that has the boot files on it, so essentially only using one sd card or usb for both roms and boot for my rasperri pi 3?
      • loak
        loak last edited by loak
        Hi bizmoan,
        You can add files to the SDcard but it's a Linux system, not so easy if you don't know or through the network (if your Recalbox is linked to your home's network) but it can be slow.
        The best way (and the safest) is to have Recalbox system on the SDcard and USB key with data. You will just have to plug the key into your computer to add roms.
        Have a look at the Wiki : https://github.com/recalbox/recalbox-os/wiki/Mini-How-To-(EN) you' will find a lot of explanations.
        Recalbox last update
