    Odroid XU4. Wireless gamepad
    odroid xu4 wireless gamepad
    2165
    • Daniele
      Daniele last edited by
      Goodmorning everyone. Excuse me in advance I'm not very practical about computer science. I bought a console based on odroid xu4, the package also put me a Bluetooth dongle. But I can not pair the 8bitdo device. I read that entering the system of the machine is successful ... But I more than the front-end menu and recall manager I can not do. Would anyone kindly tell me a step by step procedure? Thanks a lot!
      Buongiorno a tutti. Scusate in anticipo sono poco pratico di informatica. Ho acquistato una console su base odroid xu4, nella confezione mi hanno messo anche un dongle Bluetooth. Io però non riesco ad accoppiare la periferica 8bitdo. Leggevo che entrando nel sistema della macchina si riesce... Io però più del menu front-end e recall manager non riesco a fare. Qualcuno avrebbe la gentilezza di indicarmi una procedura step by step? Grazie mille!
      • FoXzFLoW
        FoXzFLoW last edited by
        Hi! I also own an Odroid XU4 and 8Bitdo SF30 Pro controller that I was not able to pair from the ES menu but I could using the "bluetoothctl" utility.
        Check the following thread, this was the solution for me:
        https://forum.recalbox.com/topic/12090/utilisation-bluetooth-sur-odroid-xu4/50
        I think that this fix will be included in the next stable release 🙂
        Regards
        • olivierdroid92
          @Daniele
          Correct, all information from @FoXzFLoW are fine.
          Using "bluetoothctl" agent in SSH mode will help you.
          Hope update will come in the official stable release
          Daniele 1 Reply Last reply Reply Quote 0
          • Daniele
            Daniele @olivierdroid92 last edited by
            @olivierdroid92
            Grazie! Scusa come si entra in modalità SSH? Premetto che non ho un PC... Ho solo un Tablet e una tastiera usb
              @Daniele
              https://www.youtube.com/watch?v=Bt4aHZ2Xo2g&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=12
              enable subtitles.
              • Daniele
                Grazie ragazzi! Funziona. Ho provato ad accendere e spegnere più volte e il controller viene rilevato automaticamente. Ho fatto un po' fatica all inizio perché nonostante recalbox mi avesse trovato la periferica non riusciva a connettersi. Poi ho provato a ancora con i comandi sul root e nonostante il messaggio su RB di periferica non trovata, il controller funzionava comunque! Ottimo
