    Solved System does not accept packs collection does not appear in system !!!
    Testers's corner
    does accept packs collection appear
    • cometsarcade
      cometsarcade last edited by
      Re: [Testers wanted: major system upgrade (Pi3b+](KODI 17 and much more ...))
      I tested an image on a PI3 with sandisk 32 original 10 class card, I did image with etcher, recorded everything ok, but at the time of creating or putting custom packs I had in the previous image, they do not appear in the list, but everything is on thema card that I use cometsarcadev2 from my previous system, would you know why es-system is not accepting packs collections?
      cometsarcade 1 Reply Last reply Reply Quote 0
      • cometsarcade
        cometsarcade @cometsarcade last edited by
        @cometsarcade <system>
        <fullname>mamekof</fullname>
        <name>neogeo</name>
        <path>/recalbox/share/roms/mamekof</path>
        <extension>.zip .ZIP .7z .7Z</extension>
        <command>python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc %CONTROLLERSCONFIG% -system %SYSTEM% -rom %ROM% -emulator %EMULATOR% -core %CORE% -ratio %RATIO% %NETPLAY%</command>
        <platform>neogeo</platform>
        <theme>mamekof</theme>
        <emulators>
        <emulator name="libretro">
        <cores>
        <core>mame2010</core>
        <core>mame078</core>
        <core>fba</core>
        <core>imame4all</core>
        <core>mame2003_plus</core>
        </cores>
        </emulator>
        <emulator name="fba2x">
        <cores>
        <core>fba2x</core>
        </cores>
        </emulator>
        </emulators>
        </system>
        I discovered in the new beta we have to change the line
        <name> neogeo </ name> for <name> pack name </ name> you are creating in the old version did not need
          voljega Banned @cometsarcade last edited by
          @cometsarcade this is not an official system'of recalbox at all, so no support for it
