    Question about emulator choices and files
    choices
    • ogroto
      ogroto last edited by
      Hello everyone. My question is about the file where it saves the selection of the emulator for each arcade game, let's say MK3 with mame2003 . I am looking for that specific file or cfg. And also the one that stores the inputs config through mame with tab on the keyboard, let's say MK3 again and when you remap the buttons it automatically saves but i cannot find the file. Thanks in advance
        voljega Banned @ogroto last edited by
        @ogroto said in Question about emulator choices and files:
        gamelist.xml of the mame directory
        Its somewhere in a mame2003 directory maybe inside saves directory ? or bios ? or mame roms dir ?
        ogroto 1 Reply Last reply Reply Quote 0
        • ogroto
          ogroto @voljega last edited by
          @voljega Thank you i will test the gamelist and see if i can find the other. Save folder sounds like it is mostly
