    Solved Arcade Folder Missing on UI
    arcade missing
    • JifferWap
      JifferWap last edited by
      Hey Guys,
      I am using the Emulga theme and before I updated to newest version, my ARCADE entry was on the UI, and it's full of roms. After update, the ARCADE entry does not appear on the theme. Switching to the default theme, it is also missing. I am new to all of this, but I'm learning quick. Any ideas? Thanks for your help.
      voljega 1 Reply Last reply Reply Quote -1
        voljega Banned @JifferWap last edited by
        @jifferwap There is no arcade folder on Recalbox official version and never has been.
        You have been using the Emulga image which is not official version and thus not supported at all by Recalbox team.
        JifferWap 1 Reply Last reply Reply Quote 1
        • JifferWap
          JifferWap @voljega last edited by
          @voljega Okay, so if I use vanilla recalbox, do I just move those roms to each of those specific emulator folders? (fba_libretro, mame) etc?
            voljega Banned @JifferWap last edited by voljega
            @jifferwap yes 🙂
            if you're using mame2010 romset you'll also have to modify defaut emulator for mame system in recalbox.conf either manually or by ES menu
