    Can't add a startup script
    cant startup script
    • marcussouza
      marcussouza last edited by marcussouza
      Hello,
      I'm following all the procedures of this post: https://github.com/recalbox/recalbox-os/wiki/Add-your-own-startup-script-(EN)
      but after I reboot the system de file S99custom return to it's original contents. Everything that I do in the /etc folder return to its original contents.
      I want to edit this file to insert the following script: echo 1 > /sys/module/bluetooth/parameters/disable_ertm
      I want this to be able to use my Xbox One S bluetooth controller.
      • tonificante
        tonificante last edited by
        Hi, I managed to add a custom startup script and wrote the process in the last message of this thread:
        https://forum.recalbox.com/topic/11022/how-to-autostart-a-rom-directly-on-boot/8
        Maybe it helps!
        Greetings
