    Pandora's Box controller
    GamePad/GPIO/USB encoder
    pandoras
    • Alex Blassingame
      Alex Blassingame last edited by
      I have recently built an arcade with recalbox x86_64 image. I am using the usb encoder that came with the pandora's box. Recal box recognizes the controller but when I go to configure it the up and left directions arent registering. I ran jtest and its shows no response to the up and left directions. Also both joysticks are registering as one player.
      • chilimac
        chilimac last edited by chilimac
        @alex-blassingame it is really easy to install the zero delay ribbon cable to the joystick wrong on a Pandora’s box joystick. Unplug the ribbon cable from the joystick, rotate that plug end over and install to the joystick. This should fix the problem. Hope that helps.
