    Gamecube iso fails to start
    Emulator Arcade/PC/Console
    gamecube iso fails start
    • wolverine
      wolverine last edited by
      Hello,
      I tried to transfer two isos of gamecube (Mario Sunshine, .gmc format, Beach Spikes Volleyball, .iso format) on the PC where i run the last version of Recalbox but when i try to start them they return to the menu without starting.
      The PC is a Intel NUC i3-7100u with Intel HD 620 - 16GB RAM.
      Is there something that i miss to correctly start gamecube emu? Dreamcast ISOs works perfectly (tried Daytona).
      Thank you
      • mattmame
        mattmame last edited by
        Hi,
        Do you have the correct bios for gamecube ?
        Si vous avez aimé mon post ou s’il a pu vous aider, mettez moi une petite flèche vers le haut.
        wolverine 1 Reply Last reply Reply Quote 0
        • wolverine
          wolverine @mattmame last edited by
          @mattmame i don't see any bios for gamecube in recalbox needings. Do i need it? Which is the filename?
