    Odroid C2 issues and improvement
    odroid improvement
    • Phil333
      Phil333 last edited by Phil333
      Hello everyone,
      first of all: I tested several RetroGaming stations and recalbox is the greatest "out of the box" feeling in my opinion.
      Thanks for all the time and great work invested so far!
      I have tested the latest recalbox image for my Odroid C2 and it works good.
      But I notice that the N64 emulator is a lot faster on my Raspberry Pi 3B. (sound stuttering at the C2 and game is a bit slower)
      The heat is also a lot more on the Odroid C2 which is odd because the C2 is a lot faster and should run faster or cooler at the same speed.
      BUT: I also compared the video output side by side from the Odroid and the Raspberry.
      The Odroid looks to be a much better resolution (aber 3-4 times better) but I cant find a way to reduce it.
      Its much more important for me to have a smooth gameplay then "high resolution" (which is on these retro games a even not that important).
      If I go ingame and using the Liberto emulator I can use the Hotkey + B button combination to change the resolution, but I cant notice any difference after that (nor at the resolution neither at the game play speed).
      Where can I change the video resolution?
      Second issue I noticed:
      I also tested Kodi which works a lot smoother compared to Raspberry and really great on th Odroid C2.
      But I cant install the addon "Vu+/Enigma" as a PVR client.
      After activating it at the System Options -> TV it automatically gets disabled and a message appears, that there is no PVR client enabled. (I also tested it on the Raspberry Pi 3B and it works there with no issues with the same settings).
      I appreciate any help and hint.
      Thanks a lot and thanks for this great software!
      Phil
