    [FIXED] PS Controller cant be used
    [fixed] cant used
    • mrvinc
      mrvinc last edited by
      Hello, for some reason i cant use the PS3 Controller (Modle no. cechzc2e). I tryed with USB and also BT.  Is there no support for this Model at recalboxOS v3.3.0-beta-14?
      • guzzo
        guzzo last edited by
        Your BT dongle is in the compatibility list  ? https://github.com/digitalLumberjack/recalbox-os/wiki/Compatibility-%28EN%29
        • mrvinc
          I dont know the Modlename from my BT dongle, but i tryed a controller from a friend and it works. So i think my controller isn't supported?!
          • mrvinc
            Update: i fixed the problem. The solution was to "reset" the controller. There is a small button on the back to do this. You need a small stick to press the button.   Thanks.
