    N64 problems with joystick on Raspberry Pi
    joystick
    • aciddreamer
      aciddreamer last edited by
      Hi, im having troubles with the joystick on the n64 emulator, it always worked fine but with the last upgrade the buttons all are screw! only 2 buttons work fine and the others seems to be on the right stick, also on the left stick up is down and down is up, cant figure it out why!!! i modified the .ini file so i can remap it but no luck, after save it and start a game it goes back to the way it was, any ideas
      • aciddreamer
        ook solved the thing is that u dont have to config the right stick at least on this controller sooo ill delete the post when im allowed...thanks
