    Recent update NO SOUND
    recent update sound
    • XchrisX
      XchrisX last edited by
      hello, i just updated recalbox lastnight 7-7-18 via automatic update and now i have no sound at all from my pc. i am running recalbox flashed onto a HDD.
      mattmame Substring 2 Replies Last reply Reply Quote 0
      • mattmame
        mattmame @XchrisX last edited by mattmame
        @xchrisx have you Tried audio menu and then sound level ?
        Else, you try modify sound un the web page http://Recalbox
        In my case I use jack and it’s the only menu Where I can set this
        Si vous avez aimé mon post ou s’il a pu vous aider, mettez moi une petite flèche vers le haut.
          Substring @XchrisX last edited by
          @xchrisx known problem ... hich should be finally gone starting from this version
          Run ssh, go TERM=xterm alsamixer, unmute olayback devices and raise their volume + set the right output in ES
