    Solved No music in games Sega SD
    Emulator Arcade/PC/Console
    music sega
    • LRN
      LRN last edited by
      Hi!
      There is no music in the games. There are sounds, but music does not play!
      What could be the problem?
      Thank you.
      p.s. sorry for the translation
      • abunille
        abunille @LRN last edited by abunille
        @lrn
        Hi,
        Which file extension do you have?
        Looks like you want to start an .iso, which have also .wav files.
        Is that correct, you need a .cue file.
        • LRN
          LRN last edited by
          Thanks, I'll try!
          • GmoAndres
            GmoAndres last edited by
            Hi!
            you need the BIOS!
            and the ."cue" for every "bin" . This happens specially in Sega CD; in playstation the "bin" is enougth
            • LRN
              LRN last edited by
              I found the files in the .cue, everything worked!
              Thank you.
              101.4k
