    Recalbox 18.04.20 > Ne boote plus
    recalbox 18.04.20 boote
    7871
    • vdeolive
      vdeolive last edited by
      Surprise aujourd'hui, ma recalbox ne boot plus. Aussi je m'en remets à votre expertise après avoir testé plusieurs choses.
      J'ai vérifié l'alim et la carte SD tout à l'air en ordre.
      La LED rouge est allumée
      La LED Verte ACT s'allume puis clignote ce qui me fait penser au le problème se situe plus au niveau de l'accès aux fichiers
      Sur la partition Boot j'ai bien les fichiers
      /overlays
      /System Volume Information
      .keep
      bcm2710-rpi3-b.dtb
      bootcode.bin
      cmdline.txt
      config.txt
      fixup.dat
      recalbox-boot.conf
      start.elf
      zImage
      Le fichier cmdline.txt donne :
      dwc_otg.fiq_fix_enable=1 sdhci-bcm2708.sync_after_dma=0 dwc_otg.lpm_enable=0 console=tty3 consoleblank=0 loglevel=3 elevator=deadline vt.global_cursor_default=0 logo.nologo root=/dev/mmcblk0p2 rootwait fastboot noswap ro
      Le fichier config.txt donne :
      uncomment if you get no picture on HDMI for a default "safe" mode
      #hdmi_safe=1
      disable_overscan=1
      uncomment to force a specific HDMI mode (this will force VGA)
      #hdmi_group=1
      #hdmi_mode=1
      comment to get jack audio
      hdmi_drive=2
      Using /etc/modules is deprecated and no longer supported on 4.4 kernel
      So manually enable audio
      dtparam=audio=on
      config_hdmi_boost=1
      force hdmi while the tv can take time before sending the signal on the hdmi output
      hdmi_force_hotplug=1
      uncomment for composite PAL
      #sdtv_mode=2
      uncomment for lirc-rpi
      #dtoverlay=lirc-rpi
      if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or give a low resolution because tv had no enough time to initialize it
      boot_delay=3
      uncomment if you don't want the rainbow at startup
      disable_splash=1
      default CEC name
      cec_osd_name=recalbox
      Overclock
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=512
      avoid_safe_mode=1
      kernel=zImage
      arm_freq=1300
      core_freq=500
      sdram_freq=575
      force_turbo=0
      over_voltage=4
      over_voltage_sdram_p=6
      over_voltage_sdram_i=4
      over_voltage_sdram_c=4
      gpu_freq=500
      sdram_schmoo=0x02000020
      Je ne trouve pas de solution pour rebooter ma recalbox malgrés mes recherches.
      Est-ce qu'une âme charitable pourrait m'aider svp?
      En vous remerciant.
      Cordialement
        Substring @vdeolive last edited by
        @vdeolive tu peux essayer en virant l'overclock ?
        • vdeolive
          J'ai supprimé l'overclock
          #hdmi_safe=1
          disable_overscan=1
          #hdmi_group=1
          #hdmi_mode=1
          hdmi_drive=2
          dtparam=audio=on
          config_hdmi_boost=1
          #sdtv_mode=2
          #dtoverlay=lirc-rpi
          boot_delay=3
          disable_splash=1
          default CEC name
          Overclock
          gpu_mem_256=0
          gpu_mem_512=0
          gpu_mem_1024=0
          avoid_safe_mode=1
          kernel=zImage
          arm_freq=1200
          core_freq=500
          sdram_freq=575
          force_turbo=0
          over_voltage=4
          gpu_freq=400
          Ce qui me gêne c'est qu'il n'y a même pas d'écran noir sur la TV.
          Rien ne passe vers la sortie HDMI
          Le PI reste avec la LED rouge allumée et la verte qui clignote encore.
          Une autre idée svp?
          En vous remerciant.
          Cordialement
          • vdeolive
            vdeolive last edited by vdeolive
            Ne seraient ce pas les fichiers start.elf ou zImage qui seraient corrompus?
            Si oui, peut on en réinjecter de nouveaux?
            En vous remerciant.
            • vdeolive
              Je précise que la carte SD est une Sandisk Ultra 128Go
              Class10 achetée sur amazon
              • vdeolive
                La manette bt se connecte ce qui signifie que le pi et le système fonctionnent
                  @vdeolive tu as accès en ssh ?
                  • vdeolive
                    cela semble possible. La prise reseau est allumée
                    J'ai utilisé cyberduck avec un cable reseau relié a mon pc
                    je fais ouvrir une nouvelle connexion SSH avec root // recalboxroot
                    mais la recalbox ne renvoit pas une IP valide (169.254.189.182)
                    Et la connexion échoue.
                    • vdeolive
                      Je viens de connecter le PI a ma box ald du PC (merci le forum) et ca marche
                      Je suis connecté au PI par réseau \RECALBOX.
                      J'ai accès aux repertoires Root et Share, ce qui est une bonne nouvelle car celà veut dire que le Pi n'est pas flingué et qu'au pire je peux faire un backup de mes ROMS patiemment triées et scrappées. :).
                      Qu'est ce que je dois modifier désormais pour retrouver un affichage HDMI svp?
                      En vous remerciant.
                        @vdeolive une archive de support stp. Tu n'as meme pas la vidoe d'intro ?
                        • vdeolive
                          J'ai accès à tout via le réseau
                          tout fonctionne.
                          En revanche le PI n'envoit pas de signal vers l'écran.
                          Quel archive de support veux tu?
                          le Recalbox.conf?
                          System Variable
                          You can configure your recalbox from here
                          To set a variable, remove the first ; on the line
                          ------------ A - System Options -----------
                          Uncomment the system.power.switch you use
                          ;system.power.switch=ATX_RASPI_R2_6 # http://lowpowerlab.com/atxraspi/#installation
                          ;system.power.switch=MAUSBERRY # http://mausberry-circuits.myshopify.com/pages/setup
                          ;system.power.switch=REMOTEPIBOARD_2003 # http://www.msldigital.com/pages/support-for-remotepi-board-2013
                          ;system.power.switch=REMOTEPIBOARD_2005 # http://www.msldigital.com/pages/support-for-remotepi-board-plus-2015
                          ;system.power.switch=WITTYPI # http://www.uugear.com/witty-pi-realtime-clock-power-management-for-raspberry-pi
                          ;system.power.switch=PIN56ONOFF # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
                          ;system.power.switch=PIN56PUSH # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
                          ;system.power.switch=PIN356ONOFFRESET # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
                          ;system.power.switch=PIN356PUSHRESET # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
                          fbcp FrameBuffer Copy Program
                          For small TFT screen on GPIO and SPI
                          See https://github.com/recalbox/recalbox-os/wiki/Utility---Use-of-fbcp-for-small-TFT-screen-(EN) for details
                          Needed for Waveshare 3.2" 3.5" TFT screen, 2.8" Adafruit screen
                          See https://github.com/recalbox/recalbox-os/wiki/TFT-Screen-SPI-Bus-(EN)
                          for support and configuration details needed by /boot/config.txt
                          system.fbcp.enabled=0
                          Recalbox Manager (http manager)
                          system.manager.enabled=1
                          1 or 2, depending on the manager version you wish
                          system.manager.version=2
                          Recalbox security
                          enforce security
                          samba password required
                          disable virtual gamepads
                          system.security.enabled=0
                          Recalbox API (REST)
                          system.api.enabled=1
                          Allow a specific resolution for ES only from the command : tvservice -m [MODE]
                          Leave commented for the default usual behaviour
                          ;system.es.videomode=CEA 4 HDMI
                          EmulationStation
                          menu style
                          default -> default all options menu
                          none -> no menu except the game search menu
                          bartop -> less menu, only needed for bartops
                          emulationstation.menu=default
                          Select a system to show on boot (use rom directory name) (string)
                          emulationstation.selectedsystem=favorites
                          Show the gamelist of the first or selected system on boot (0,1)
                          emulationstation.bootongamelist=0
                          Disable system view ES will boot and show ONLY the first or selected system (0,1)
                          emulationstation.hidesystemview=0
                          Pa**e Gamelists only. Show only games listed in gamelist.xml files (0,1)
                          emulationstation.gamelistonly=0
                          Force basicgameList view to be displayed, even if your game systems are scraped (0,1)
                          emulationstation.forcebasicgamelistview=0
                          Emulator special keys
                          default -> default all special keys
                          nomenu -> cannot popup the emulator menu
                          none -> no special keys in emulators
                          Show or hide kodi in emulationstation (0,1)
                          kodi.enabled=1
                          Start kodi at launch (0,1)
                          kodi.atstartup=0
                          set x button shortcut (0,1)
                          kodi.xbutton=1
                          Allow a specific resolution for Kodi only from the command : tvservice -m [MODE]
                          By default is using the default resolution of your screen
                          kodi.videomode=default
                          Kodi can wait for a network component before starting
                          waithost is the ip or hostname that must answer to a ping to validate the availability
                          waittime is the maximum time waited when kodi boots
                          if waitmode is required, kodi will not start if the component is not available
                          if waitmode is wish, kodi will start if the component is not available
                          if waitmode is not set or has another value, kodi will start immediately
                          ;kodi.network.waittime=10
                          Hyperion
                          Hyperion allows you to use an ambilight like led system on your recalbox
                          Use hypercon to create your configuration file, and copy it in /recalbox/share/system/configs/hyperion/hyperion.config.json
                          hyperion.enabled=0
                          ------------ B - Network ------------
                          Set system hostname
                          system.hostname=RECALBOX
                          Activate wifi (0,1)
                          wifi.enabled=1
                          Wifi SSID (string)
                          wifi.ssid=Freebox-647D38
                          Wifi KEY (string)
                          after rebooting the recalbox, the "new key" is replace by a hidden value "enc:xxxxx"
                          you can edit the "enc:xxxxx" value to replace by a clear value, it will be updated again at the following reboot
                          Escape your special chars (# ; $) with a backslash : $ => $
                          xxxxxxxxx
                          secondary wifi (not configurable via the user interface)
                          ;wifi2.ssid=new ssid
                          ;wifi2.key=new key
                          third wifi (not configurable via the user interface)
                          ;wifi3.ssid=new ssid
                          ;wifi3.key=new key
                          Samba share
                          system.samba.enabled=1
                          Virtual Gamepads
                          SSH
                          system.ssh.enabled=1
                          ------------ C - Audio ------------
                          Set the audio device (auto, hdmi, jack)
                          audio.device=auto
                          Set system volume (0..100)
                          audio.volume=97
                          Enable or disable system sounds in ES (0,1)
                          audio.bgmusic=1
                          -------------- D - Controllers -----------------
                          Enable support for standard bluetooth controllers
                          Please enable only one of these
                          -------------- D1 - PS3 Controllers ------------
                          controllers.ps3.enabled=1
                          Choose a driver between bluez, official and shanwan
                          bluez -> bluez 5 + kernel drivers, support official and shanwan sisaxis
                          official -> sixad drivers, support official and gasia sisaxis
                          shanwan -> shanwan drivers, support official and shanwan sisaxis
                          controllers.ps3.driver=bluez
                          ------------ D2 - GPIO Controllers ------------
                          GPIO Controllers
                          enable controllers on GPIO with mk_arcarde_joystick_rpi (0,1)
                          controllers.gpio.enabled=0
                          mk_gpio arguments, map=1 for one controller, map=1,2 for 2 (map=1,map=1,2)
                          controllers.gpio.args=map=1,2
                          ------------ D3 - Steam Controllers ------------
                          Enable steam controller service
                          controllers.steam.enabled=0
                          DB9 Controllers
                          Enable DB9 drivers for atari, megadrive, amiga controllers (0,1)
                          controllers.db9.enabled=0
                          db9 arguments
                          controllers.db9.args=map=1
                          Gamecon controllers
                          Enable gamecon controllers, for nes, snes psx (0,1)
                          controllers.gamecon.enabled=0
                          gamecon_args
                          XGaming's XArcade Tankstik and other compatible devices
                          controllers.xarcade.enabled=1
                          ------------ F - Language and keyboard ------------
                          Set the language of the system (fr_FR,en_US,en_GB,de_DE,pt_BR,es_ES,it_IT,eu_ES,tr_TR,zh_CN)
                          system.language=fr_FR
                          set the keyboard layout (fr,en,de,us,es)
                          system.kblayout=us
                          Set you local time
                          Select your timezone from : ls /usr/share/zoneinfo/ (string)
                          system.timezone=Europe/Paris
                          ------------ G - UPDATES ------------
                          Automatically check for updates at start (0,1)
                          updates.enabled=1
                          Update type : default to stable
                          updates.type=stable
                          ------------ H - HERE IT IS - GLOBAL EMULATOR CONFIGURATION ------------
                          The global value will be used for all emulators, except if the value
                          is redefined in the emulator
                          Set game resolution for emulators
                          select your mode from the command : tvservice -m [MODE]
                          CEA 5 HDMI : 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
                          CEA 4 HDMI : 1280x720 @ 60Hz 16:9, clock:74MHz progressive
                          use 'default' for using the default resolution
                          use 'auto' : switches to CEA 4 HDMI if supported, else keep the current resolution
                          (string)
                          global.videomode=CEA 4 HDMI
                          Shader set
                          Automatically select shaders for all systems
                          ## (none, retro, scanlines)
                          global.shaderset=none
                          Once enabled, your screen will be cropped, and you will have a pixel perfect image (0,1)
                          global.integerscale=0
                          Set gpslp shader for all emulators (prefer shadersets above). Absolute path (string)
                          global.shaders=hq2x
                          Set ratio for all emulators (auto,4/3,16/9,16/10,custom)
                          global.ratio=16/9
                          Set smooth for all emulators (0,1)
                          global.smooth=1
                          Set rewind for all emulators (0,1)
                          global.rewind=0
                          Set autosave/load savestate for all emulators (0,1)
                          global.autosave=0
                          Enable retroarchievements (0,1)
                          Set your www.retroachievements.org username/password
                          global.retroachievements=1
                          global.retroachievements.hardcore=0
                          Set retroarch input driver (auto, udev, sdl2)
                          If you don't have issues with your controllers, let auto
                          global.inputdriver=auto
                          If you do not want recalboxOS to generate the configuration for all emulators (string)
                          ------------ I - EMULATORS CHOICES -----------
                          You can override the global configuration here
                          Here is the snes example
                          ;snes.videomode=CEA 4 HDMI
                          snes.core=snes9x_next
                          ;snes.ratio=16/9
                          ;snes.smooth=0
                          ;snes.rewind=1
                          ;snes.autosave=0
                          snes.emulator=libretro
                          ;snes.integerscale=0
                          If you do not want recalboxOS to generate the configuration for the emulator :
                          Default cores for RPi3
                          gba.core=mgba
                          mame.core=default
                          nes.core=default
                          NeoGeo emulator
                          You can use pifba or a libretro core (fba2x,libretro)
                          neogeo.emulator=libretro
                          If you set libretro as neogeo.emulator, the line below sets the retroarch core (fba,imame4all)
                          neogeo.core=fba
                          N64 emulator is configured to display a screen with a 640x480 resolution (native n64 resolution)
                          So you must use one of these video modes (DMT 4 HDMI,CEA 1 HDMI).
                          If your screen is not compatible with one of these video modes, please check the recalbox's wiki.
                          n64.videomode=DMT 4 HDMI
                          If you are using a CRT screen, please change the setting above with this one :
                          n64.videomode=default
                          Dreamcast emulator
                          Like N64, such a CPU intensive emulator needs a small resolution
                          Consider DMT 4 HDMI (640480) or DMT 9 HDMI (800600). If you have a black screen on dreamcast, try DMT 9 HDMI here
                          dreamcast.videomode=DMT 4 HDMI
                          Configurations generated by Recalbox
                          psx.emulator=libretro
                          psx.core=pcsx_rearmed
                          psx.ratio=auto
                          scummvm.ratio=16/9
                          n64.emulator=default
                          prboom.emulator=libretro
                          scummvm.emulator=default
                          n64.core=default
                          nes.emulator=default
                          pcenginecd.emulator=default
                          mame.emulator=default
                          megadrive.emulator=default
                          segacd.emulator=libretro
                          segacd.core=genesisplusgx
                          prboom.core=prboom
                            @vdeolive pitié ne pas mettre de copier/coller de fichiers de config ... Tu vas sur http://recalbox/help tu génères l'archive de support et tu me donnes le lien produit
                            • vdeolive
                              @substring :
                              "https://file.ac/VDQqLnBdaqQ/"
                              • vdeolive
                                Désolé. Voici l'archive support.
                                Merci pour ton aide
                                • vdeolive
                                  J'ai bidouillé tout ce que j'ai pu mais rien a changer.
                                  Le Pi ne renvoie toujours pas d'image vers la sortie HDMI.
                                  Une autre idée svp?
                                    @vdeolive vire l'overclock
                                    • vdeolive
                                      J'ai supprimé toute la partie overclock du fichier Config.txt sur la carte SD.
                                      Rien n'y fait, il n'y a toujours rien à l'écran malheureusement.
                                      Une autre idée stp?
                                      En te remerciant
                                      • vdeolive
                                        Le PI semble fonctionner c'est juste qu'il n'affiche rien sur la sortie HDMI.
                                        Avant lorsque l'on allumait, le PI envoyait un signal a la TV et prenait le contrôle de l'affichage même sans selectionner la chaine source sur HDMI 1
                                        Aujourd'hui c'est plus le cas. Plus de son plus d'image.
                                          @vdeolive tu as testé sur quels écrans ? Parce qu'effectivement le Pi ne trouve pas d'écran
                                          • vdeolive
                                            Sur mes 2 TVs sur lesquelles je joue habituellement.
                                            Une samsung 49'' et une LG 22".
