    Guide: How Scrap Files the most easy and fast way
    guide scrap
    • hotmetal
      hotmetal last edited by
      1.- Power on your Raspberry pi, and connect to the network. (wifi /lan) 2.- Download the scraper.zip,  and unzip the scraper.exe in the rom folder (in this case sega master system). 3.- Execute que scraper.exe and whait to the software finish the job. 4.- Now you have to edit the gamelist.xml (if you dont do this, you will not see your images), open the gamelist.xml with WordPad, and press the replace button and find this ">./images/" , and replace for ">~/.emulationstation/downloaded_images/mastersystem/", replace all and save. 5.- Now you have to download and install WinSCP, and log in : fileprotocol: SCP, Hostname: recalbox, port:22, user name: root, password: recalboxroot. 6.- Navigate to the root folder, right click and GO TO -> Open Directory, and type "/root/.emulationstation/ " and press ok. 7.- Now you can drop your images and gamelist.xml to the <span id="result_box" class="short_text" lang="en"><span class="hps">corresponding folders (you can create the folder if is not there) </span></span> gamelist.xml: gamelists/mastersystem images: downloaded_images/mastersystem 8.- Restart your Raspberry pi, and njoy.
