    PC v18.04.20 Wifi/Bluetooth issue
    v18.04.20 wifibluetooth issue
    6936
    • halathos
      halathos last edited by
      So I've been trying to build a few different PCs up with recalbox for a fun hobby. Never had issues with any hardware until today. I've been trying to use wifi and bluetooth with the Intel Centrino Wireless-N 2230 2230BNHMW chip. Now I've searched the forums and found nothing that either worked or was relevant. Every unit I build I test with a bootable Ubuntu of both 18.04 LTS and 18.10 and as you say if it works with linux it will work with recalbox. I've tried this card on Ubuntu(s) and my Windows To Go stick. I've set the SSID and wifi key manually, I've tried adding known working bluetooth devices and have just recently added a cheap iogear bluetooth 4 dongle that just uses generic drivers anyway and it seems to function with the dongle only. I haven't had a chance to check what kernel recalbox was using but I believe 4.8 had support for this card. I will have to check if 4.10 came out yet. (Been a while since I've reviewed the changelog on the linux kernal.)
        Substring @halathos last edited by
        @halathos need dmesg output to know which drivers/firmare are missing
        halathos 1 Reply Last reply Reply Quote 0
        • halathos
          halathos @Substring last edited by
          @substring [0_1526230972593_dmesg.txt](Uploading 100%)
          https://www.dropbox.com/s/j10kdm6thvdjgll/dmesg.txt?dl=0
            @halathos And here is why it's not working:
            [    3.254577] Intel(R) Wireless WiFi driver for Linux
            [    3.254578] Copyright(c) 2003- 2015 Intel Corporation
            [    3.254710] iwlwifi 0000:04:00.0: can't disable ASPM; OS doesn't have ASPM control
            [    3.254904] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-2030-6.ucode failed with error -2
            [    3.254911] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-2030-5.ucode failed with error -2
            [    3.254911] iwlwifi 0000:04:00.0: no suitable firmware found!
            [    3.268401] bluetooth hci0: Direct firmware load for brcm/BCM20702A1-0a5c-21e8.hcd failed with error -2
            [    3.268403] Bluetooth: hci0: BCM: Patch brcm/BCM20702A1-0a5c-21e8.hcd not found
            Regarding the wifi, there was a very same topic this month. So you need to find the missing files and put them in /lib/firmware. Mind the path for the .hcd file
            halathos 1 Reply Last reply Reply Quote 1
            • halathos
              @substring I will look for the thread and see if I find it, what I am comfortable with changing myself. Thank you very much! I'm hoping I can get this figured out as I feel a bit lost.
                @halathos my answr was mostly for people who are a little familiar with file handlingin Linux. But i can give a more detailled answer
                • halathos
                  @substring I very much appreciate that, I am reasonably versed within linux and have managed to get my way around so far. Any help you can give would be very much appreciated.
                    @halathos well you look like you have the required knowledge to sort this out by yourself 🙂 Just google for the files, drop them in the right folders (/lib/firmware for the wifi fw, /lib/firmware/brcm for the BT fw, you may need to mkdir the brcm folder).
                    halathos 2 Replies Last reply Reply Quote 1
                    • halathos
                      halathos last edited by halathos
                      @Substring I've got the files but I've just dropped them on the share for now. trying to get filemanager working to move them to the appropriate folders and the kodi FM doesn't have write access to /lib/. I'm so close but so far away 🙂
                      • halathos
                        @substring well I tried to Chmod the folder but no luck. Any other helpful hints 🙂
                        • NeeeeB
                          NeeeeB last edited by
                          SSH and this command
                          mount -o remount,rw /
                          Vieux geek ^^
                          • halathos
                            halathos @halathos last edited by
                            @halathos said in PC v18.04.20 Wifi/Bluetooth issue:
                            figured out how to write using Kodi filemanager (Didn't feel like plugging in a keyboard)
                            "mount -o remount, rw /"
                            Now to reboot and I will report back with results.
                            • NeeeeB
                              lol you beat me to it !!
                              Vieux geek ^^
                              • halathos
                                @substring Still no luck on this. Wifi is not populating and Bluetooth cant find anything I have updated my dmesg in the dropbox link but just in case. It seems to have taken the files and used them properly. I feel like I'm missing something. https://www.dropbox.com/s/j10kdm6thvdjgll/dmesg.txt?dl=0
                                • halathos
                                  Well update on this, WiFi disable and delete stored values from my manual attempt and reboot and re enable got it working. Bluetooth although disabled and re enabled through recalbox.conf with reboot and removal of ../system/bluetooth/.. to make sure no settings were left over.
                                    @halathos so ? Success or not ?
                                    • halathos
                                      @substring no after a few reboots the wifi takes a while to initialize and bluetooth will not find anything. even external has stopped finding anything. updated the demsg just above. i'm going to continue to plug away at it. if you have any ideas it would be great 🙂
                                        @halathos it dies say the wifi is ok 😕
                                        For bt, can you type hciconfig and give me the output ?
                                        • halathos
                                          @substring no output without the dongle. with the dongle I get
                                          hci0: Type: BR/EDR Bus: USB
                                          BD Address: 5C:F3:70:85:88:98 ACL MTU: 1021:8 SCO MTU: 64:1
                                          DOWN
                                          RX bytes:6760 acl:0 sco:0 events:820 errors:0
                                          TX bytes:72686 acl:0 sco:0 commands:818 errors:0
                                          Still no pairing. (No controllers found)
                                          FYI these are known working controllers even with this dongle.
                                          My apologies for the late response. Work life catches up once in a while 🙂
                                            @halathos not pairing because it's down. Weird, there is a udev rule that should bring hci0 up
                                            halathos 2 Replies Last reply Reply Quote 0
