    Opening recalbox.img.xz file using etcher
    opening recalbox.img.xz file etcher
    3197
    • Grezmondo81
      Grezmondo81 last edited by
      I'm using a Mac to download the file for Raspberri pi 2. I've downloaded the .xz file successfully, and also installed Etcher. When I select the file in etcher it repeatedly say "File Format not recognized." I've repeated the process over and over but had no joy. Can anyone help…???
        Substring @Grezmondo81 last edited by
        @grezmondo81 have you verified the checksum of the file ?
        Grezmondo81 1 Reply Last reply Reply Quote 0
        • Grezmondo81
          Grezmondo81 @Substring last edited by
          @substring How do I do that?
            @grezmondo81 download the .sha1 file of the image and verify it with a software that xan compute sha1 from a file. You're on mac, i can't help you more. The aim is t make sure your diwnload is valid
            • Grezmondo81
              @substring The download seems valid. Although when I try to open the zipped file it simply duplicates the file again (creates a .2 version). Tried everything
              • abunille
                abunille @Grezmondo81 last edited by
                @grezmondo81
                Try to extract the file with example The Unarchiver.
                And if Etcher fails again, try ApplePi-Baker.
                I never used Etcher on Mac.
                • Grezmondo81
                  Grezmondo81 @abunille last edited by
                  @abunille Will do! Thanks!
