    Logitech F710: Problem with one of two Controllers
    GamePad/GPIO/USB encoder
    logitech f710
    • lltodoll
      lltodoll last edited by
      Hi guys,
      i have a problem with my Logitech F710 controllers.
      One of them connect directly, but the second controller doesen't work. (try in both mode Xinput and DirectInput).
      Logfile:
      [code]
      Apr 30 07:07:58 RECALBOX user.info kernel: [ 176.968688] hid-generic 0003:046D:C22F.0005: hiddev0,hidraw1: USB HID v1.11 Device [Logitech Logitech Cordless RumblePad 2] on usb-3f980000.usb-1.2.4/input1
      Apr 30 07:08:04 RECALBOX user.info kernel: [ 182.916856] usb 1-1.2.4: USB disconnect, device number 6
      Apr 30 07:08:05 RECALBOX user.info kernel: [ 183.193889] usb 1-1.2.4: new full-speed USB device number 7 using dwc_otg
      Apr 30 07:08:05 RECALBOX user.info kernel: [ 183.300717] usb 1-1.2.4: New USB device found, idVendor=046d, idProduct=c21f
      Apr 30 07:08:05 RECALBOX user.info kernel: [ 183.300740] usb 1-1.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      Apr 30 07:08:05 RECALBOX user.info kernel: [ 183.300753] usb 1-1.2.4: Product: Wireless Gamepad F710
      Apr 30 07:08:05 RECALBOX user.info kernel: [ 183.300767] usb 1-1.2.4: Manufacturer: Logitech
      Apr 30 07:08:05 RECALBOX user.info kernel: [ 183.300779] usb 1-1.2.4: SerialNumber: DFF49825
      Apr 30 07:08:05 RECALBOX user.debug kernel: [ 183.320116] xpad 1-1.2.4:1.0: xpad_prepare_next_out_packet - found pending output packet 2
      Apr 30 07:08:05 RECALBOX user.info kernel: [ 183.321380] input: Logitech Gamepad F710 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/input/input0
      Apr 30 07:08:05 RECALBOX user.info kernel: [ 183.321580] usbcore: registered new interface driver xpad
      Apr 30 07:08:05 RECALBOX user.debug kernel: [ 183.373923] xpad 1-1.2.4:1.0: xpad_irq_in - urb shutting down with status: -2
      Apr 30 07:08:05 RECALBOX user.debug kernel: [ 183.573820] xpad 1-1.2.4:1.0: xpad_irq_in - urb shutting down with status: -2
      Apr 30 07:08:05 RECALBOX user.debug kernel: [ 183.733817] xpad 1-1.2.4:1.0: xpad_irq_in - urb shutting down with status: -2
      Apr 30 07:08:05 RECALBOX user.debug kernel: [ 183.793831] xpad 1-1.2.4:1.0: xpad_irq_in - urb shutting down with status: -2
      Apr 30 07:08:05 RECALBOX user.debug kernel: [ 183.863810] xpad 1-1.2.4:1.0: xpad_irq_in - urb shutting down with status: -2
      [/code]
      Can anyone help me?
      System:
      RASPBERRY PI 3 B+
      4x 1,4 GHz,
      1 GB RAM
      Recalbox 18.04.20
      • gnubit
        gnubit last edited by
        @lltodoll
        I have had issues getting both my F710 working, my setup is different (x86_64), but my problem similar to yours. I`ll try to summarize my issues and solution in the hope it may help you out.
        The second controller works when pugged in on its own ? They both work on their own ? The reason I ask is that my controllers would disconnect (one controller more that the other, the green led near the mode button would flash). Both of my controllers would work fine when only one was plugged in at a time, it was driving me crazy !
        My fix in the end was to use the usb extension cables that came with my controllers to separate the RF dongles as they may have been interfering with one another.
        Here is a snippet from my log:
        Apr 30 10:37:56 RECALBOX user.debug kernel: [ 7.410404] xpad 1-3:1.0: xpad_prepare_next_out_packet - found pending output packet 2
        Apr 30 10:37:56 RECALBOX user.info kernel: [ 7.410460] input: Logitech Gamepad F710 as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input4
        Apr 30 10:37:56 RECALBOX user.debug kernel: [ 7.410542] xpad 1-4:1.0: xpad_prepare_next_out_packet - found pending output packet 2
        Apr 30 10:37:56 RECALBOX user.info kernel: [ 7.410589] input: Logitech Gamepad F710 as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/input/input5
        Apr 30 10:37:56 RECALBOX user.info kernel: [ 7.410636] usbcore: registered new interface driver xpad
        Apr 30 10:37:56 RECALBOX user.debug kernel: [ 7.423315] xpad 1-3:1.0: xpad_irq_in - urb shutting down with status: -2
        Apr 30 10:37:56 RECALBOX user.info kernel: [ 7.460278] lirc_dev: IR Remote Control driver registered, major 242
        Apr 30 10:37:56 RECALBOX user.debug kernel: [ 7.463315] xpad 1-4:1.0: xpad_irq_in - urb shutting down with status: -2
        Apr 30 10:37:56 RECALBOX user.debug kernel: [ 7.563309] xpad 1-4:1.0: xpad_irq_in - urb shutting down with status: -2
        Apr 30 10:37:56 RECALBOX user.debug kernel: [ 7.587351] xpad 1-3:1.0: xpad_irq_in - urb shutting down with status: -2
        Apr 30 10:37:56 RECALBOX user.debug kernel: [ 7.611308] xpad 1-4:1.0: xpad_irq_in - urb shutting down with status: -2
        Apr 30 10:37:56 RECALBOX user.debug kernel: [ 7.619378] xpad 1-3:1.0: xpad_irq_in - urb shutting down with status: -2
        • lltodoll
          I don't understand this. The second controller doesn't work with recalbox. If i connect the controller to my pc. the (not usable) controller works fine. But only in recalbox the usb dongle or controller dont work.
          Logfile:
          Oct 25 19:31:42 RECALBOX user.info kernel: [ 188.375486] usb 1-1.2.4: new full-speed USB device number 5 using dwc_otg
          Oct 25 19:31:42 RECALBOX user.info kernel: [ 188.482383] usb 1-1.2.4: New USB device found, idVendor=046d, idProduct=c22f
          Oct 25 19:31:42 RECALBOX user.info kernel: [ 188.482418] usb 1-1.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
          Oct 25 19:31:42 RECALBOX user.info kernel: [ 188.482433] usb 1-1.2.4: Product: Logitech Cordless RumblePad 2
          Oct 25 19:31:42 RECALBOX user.info kernel: [ 188.482446] usb 1-1.2.4: Manufacturer: Logitech
          Oct 25 19:31:42 RECALBOX user.info kernel: [ 188.490623] hid-generic 0003:046D:C22F.0001: hiddev0,hidraw0: USB HID v1.11 Device [Logitech Logitech Cordless RumblePad 2] on usb-3f980000.usb-1.2.4/input0
          Oct 25 19:31:42 RECALBOX user.info kernel: [ 188.496747] hid-generic 0003:046D:C22F.0002: hiddev0,hidraw1: USB HID v1.11 Device [Logitech Logitech Cordless RumblePad 2] on usb-3f980000.usb-1.2.4/input1
          Oct 25 19:31:48 RECALBOX user.info kernel: [ 194.441597] usb 1-1.2.4: USB disconnect, device number 5
          Oct 25 19:31:48 RECALBOX user.info kernel: [ 194.725488] usb 1-1.2.4: new full-speed USB device number 6 using dwc_otg
          Oct 25 19:31:48 RECALBOX user.info kernel: [ 194.832632] usb 1-1.2.4: New USB device found, idVendor=046d, idProduct=c21f
          Oct 25 19:31:48 RECALBOX user.info kernel: [ 194.832665] usb 1-1.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          Oct 25 19:31:48 RECALBOX user.info kernel: [ 194.832678] usb 1-1.2.4: Product: Wireless Gamepad F710
          Oct 25 19:31:48 RECALBOX user.info kernel: [ 194.832690] usb 1-1.2.4: Manufacturer: Logitech
          Oct 25 19:31:48 RECALBOX user.info kernel: [ 194.832702] usb 1-1.2.4: SerialNumber: DFF49825
          Oct 25 19:31:48 RECALBOX user.debug kernel: [ 194.851830] xpad 1-1.2.4:1.0: xpad_prepare_next_out_packet - found pending output packet 2
          Oct 25 19:31:48 RECALBOX user.info kernel: [ 194.852291] input: Logitech Gamepad F710 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/input/input0
          Oct 25 19:31:48 RECALBOX user.info kernel: [ 194.852459] usbcore: registered new interface driver xpad
          Oct 25 19:31:48 RECALBOX user.debug kernel: [ 194.925551] xpad 1-1.2.4:1.0: xpad_irq_in - urb shutting down with status: -2
          Oct 25 19:31:49 RECALBOX user.debug kernel: [ 195.105501] xpad 1-1.2.4:1.0: xpad_irq_in - urb shutting down with status: -2
          Oct 25 19:31:49 RECALBOX user.debug kernel: [ 195.285500] xpad 1-1.2.4:1.0: xpad_irq_in - urb shutting down with status: -2
          Oct 25 19:31:49 RECALBOX user.debug kernel: [ 195.365502] xpad 1-1.2.4:1.0: xpad_irq_in - urb shutting down with status: -2
          Oct 25 19:31:49 RECALBOX user.debug kernel: [ 195.435481] xpad 1-1.2.4:1.0: xpad_irq_in - urb shutting down with status: -2
          Oct 25 19:33:33 RECALBOX user.debug kernel: [ 299.975487] xpad 1-1.2.4:1.0: xpad_irq_in - urb shutting down with status: -2
          I think both controller are detected:
          But only one works in games and on the game selection view. Anybody can help? Thanks a lot
