    Momentary Power-Button and LED
    momentary power-button led
    • sebr
      sebr last edited by
      Hello,
      I have trouble getting a momentary power Switch and power LED to work at the same time. If I set
      system.power.switch=PIN356ONOFFRESET
      then the LED works as expected but the momentary power button does not.
      If I set
      system.power.switch=PIN56PUSH
      the power button works well but the LED is off.
      So after doing some research I cam across this post: https://forum.recalbox.com/topic/5701/momentary-power-button-with-led
      So I changed the lines mentioned in the script but not success: power button still not respond. How to adjust the script to make it work?
