    CPS1,2 compatibility?
    Emulator Arcade/PC/Console
    cps12
    • Cristian Muñoz
      Cristian Muñoz last edited by
      Gonna try to explain. I have 2 version of roms, for example.
      Cadilacs and dino 4mb found in most of the sites
      Cadilacs and dino 32mb from a rom pack much complex to find
      The 4mb version doesent start, but the 32mb start and play with no problem.
      I dont get it, the 4mb is the version i found everywere, but the 32mb i found it in a much complicated way is the only work?. So the roms are diferent? I dont wanna use the 32mb version because the whole set of roms is almost 3gb.
        voljega Banned @Cristian Muñoz last edited by
        @cristian-muñoz you obviously didn't read arcade documentation the wiki
