    GameCube: Rogue Squadron II stuck on "memory card is formatted for use in a different territory"
    Emulator Arcade/PC/Console
    gamecube rogue squadron memory card pc 64 bits territory
    • FerociousRecal
      FerociousRecal last edited by FerociousRecal
      Hello all,
      Running Recalbox 18.03.30, PC 64 bits. In the GameCube emulator I’m testing Star Wars Rogue Squadron II [GSWE64] NTSC-U and getting this error when the game comes up: "Memory Card Slot A: This memory card is formatted for use in a different territory." I did a search and found an old post but no solution (see below). I also found a post regarding the similar issue on Dolphin emulator which was solved by going to “Config > Gamecube > Slot A > GCI Folder “ but don’t see anything similar in Recalbox. Any solution?
      Thanks in advance.
      alt text
      100.7k
