    USB Soundcard - how to install ?
    dongle bluetoot голосовые поздр
    • tr1plx
      tr1plx last edited by
      Hi ! I'm using a DVI Monitor and for Sound 3,5 Jack - but the sound quality is very bad. Is there a way to get a usb soundcard to work ? typing lsusb and after connecting USB sound card there is one more device, but how to configure it ?
      • vollstrecker
        vollstrecker last edited by
        Hello, I will also update the audio quality with a usb soundcard which works great with squeezelite. But I do not know how to install it in recalbox. Is there any solution?
        • vollstrecker
          I made it in Retropie, but Recalbox is my favorite OS. Where are the experts?
          • christof-fligg
            christof-fligg last edited by
            Try it with "cat /proc/asound/cards" there you will find out if the card is installed and which number it has and then edit in "/usr/share/alsa/alsa.conf" the settings defaults.ctl.card <name/number of your sound device> defaults.pcm.card <name/number of your sound device> defaults.timer.card <name/number of your sound device> im not an expert so try this NOT with your main recalbox sd card and give me feedback
            • vollstrecker
              Thank you for your reply. Card is not found:
              [root@RECALBOX ~]# cat /proc/asound/cards
               0 [ALSA           ]: bcm2835 - bcm2835 ALSA
                                    bcm2835 ALSA
              [root@RECALBOX ~]# lsusb
              Bus 001 Device 005: ID 0d8c:013c
              Bus 001 Device 008: ID 081f:e401
              Bus 001 Device 007: ID 1a40:0101
              Bus 001 Device 006: ID 0bda:8172
              Bus 001 Device 004: ID 1a40:0101
              Bus 001 Device 003: ID 0424:ec00
              Bus 001 Device 002: ID 0424:9514
              Bus 001 Device 001: ID 1d6b:0002
              [root@RECALBOX ~]#
