    Strange error in Dosbox
    strange dosbox
    23243
    • Dragu
      @voljega
      @lmerckx
      I suppose that this is a new behavior in relation with the virtual keyboard.
      Because if you load dosbox with no dosbox.bat, he execute the foillowing commands before going to Z:
      set ROOT=/recalbox/share/roms/dos/xxxxxxx.pc
      what is totaly right. But after he make
      MOUNT C "/usr/share/dosbox"
      pointing ๐Ÿ˜„ not to the game directory, but to the virtual keyboard directory.
        voljega Banned @Dragu last edited by voljega
        @lmerckx
        @dragu
        also Wacky Wheels now lags horribly, whereas it was working perfectly fine before ....
        didn't try any other game but I suppose it will be the same
        EDIT : yeah same for Tyrian for me...
        do you have the same speed problem @Dragu ?
        bad compilation options maybe @lmerckx ?
        • lmerckx
          lmerckx last edited by lmerckx
          @Dragu @voljega
          The share problem is perhaps linked to the virtual keyboard modification.
          But for the lag, I don't see the link.
          But I also made a version b*mp which needed some SDL2 adaptations. Hmmm...
          I will check ...
          Recalbox 9.1 on RPI 4, SSD 250Gb, 2 Logitech F710, Nespi4case
          Contributions for DosBox, ScummVM, ResidualVM, Daphne (Hypseus)
          • Dragu
            @voljega
            @lmerckx
            I can also confirm the speed issue ! Just miles away from before. Some games becomes unplayable. I just tried with No Remorse, even the sound of the videos is interupted or echoed. It is as if you play with lowest framerate. Very strange.
              @Dragu
              @lmerckx
              I'm afraid that most games become unplayable, the ones I've tested are not really demanding
              • Dragu
                @voljega
                @lmerckx
                I tried some things, also CtrL+F12. There is no changement and some-times he just jump out of the game with Ctrl Keys. Just nice, in Crusader you see now the bullets flying like in MaxPayne. ๐Ÿ˜‰
                I was yesterday trying to install Oddworld and didn't arrive, so I will switch back to my Christmas SD.
                • Dragu
                  @voljega
                  @lmerckx
                  I just swapped OS, it seems to me that the speed issue is existing already from version 180209 ! So seems to be not a fresh issue. If somebody has still this not yet updated system version, he can perhaps confirm.
                  • Dragu
                    @voljega
                    @lmerckx
                    Also to note, if it can help. I have not all versions but see a notable increase of size between 2017 and 2018 :
                    OS 170417 Dosbox size 2977700
                    OS 180209 Dosbox size 5048136
                    OS 180330 Dosbox size 5111180
                    For the moment I copied back the version from 170417 to /usr/bin, and again perfect.
                      @dragu nice to know ! well maybe @lmerckx will have an idea (and 14 569 notifications ๐Ÿ˜› )
                      • Dragu
                        @voljega
                        Also something new about the MOUNT C "/usr/share/dosbox" story.
                        After copy of dosbox 2017 version, this always exist in the actual OS 180330, seems to be a configuration issue.
                        • lmerckx
                          @Dragu @voljega For the moment, not too many notifications ! ๐Ÿ˜‰
                          But sorry for the inconveniences.
                          The /usr/share/dosbox usage is clearly new to virtual keyboard. The increase of size is strange indeed: new modifications due to b*mp and virtual keyboard modification can't explain this size.
                          As voljega said before, can be due to a change in compilation directives !?
                          I will check tonight. But, on my RPI2, I detected no lag ... what are your platforms ?
                          • Dragu
                            @lmerckx
                            Dont work in the nights !
                            We have time and also a job to pay for the playing toys. ๐Ÿ™‚ Anyway, for the moment, I am fine with older version.
                            In my case it is the PI3, but are there differences also in dosbox in PI versions ?
                            And dont worry.
                              voljega Banned @lmerckx last edited by
                              @lmerckx RPI3 for me too
                              • Dragu
                                @lmerckx
                                @voljega
                                Could this be a possible explication for the volume size increase, that the 2018 build is the 64-bit version and not the 32 ?
                                • lmerckx
                                  @Dragu @voljega
                                  Back home ...
                                  I've just tested my DosBox RPI2 (updated to 18.03.30) and I confirm: I have no lag problem on games Wolfenstein 3D, Epic Pinball, Ultima 7.
                                  The size of my dosbox is 5046488.
                                  Can you send a support archive ?
                                  Edit: Now, I can reproduce the /usr/share/dosbox bug ! I've never tested without dosbox.bat, in fact.
                                  I look for a correction.
                                  Still no idea for lags.
                                  • lmerckx
                                    @Dragu Mine is still 32 bits.
                                    Here is the result of the "file dosbox" command, launched from another Linux workstation:
                                    dosbox: ELF 32-bit LSB executable, ARM, EABI5 version 1 (GNU/Linux), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, for GNU/Linux 4.4.0, stripped
                                      voljega Banned @lmerckx last edited by voljega
                                      @lmerckx doesn't work in recalbox for me : # file dosbox -sh: file: command not found
                                      tried Epic Pinball, lags horribly too :s
                                      @lmerckx do you have a RPI3 ?
                                      • lmerckx
                                        @voljega Yes, I had to transfered my dosbox exec to another Linux workstation to get "file" command.
                                        I have a RPI2.
                                        Do you also launch games with autoexec or with a dosbox.bat script ?
                                        • lmerckx
                                          @dragu So, I think I have solved the "/usr/share/dosbox" problem:
                                          When there is no dosbox.bat file in directory, DosBox scan other parameters to find a valid file to execute or directory to mount. When it find the share directory, it stops and go on with it.
                                          It explains why I had no problem. I always use the dosbox.bat file.
                                          So, the solution was to put the initialization of the virtual keyboard before the autoexec startup.
                                          But, I'm curious, how do you configure your autoexec ?
                                          Do you need to specify the mount and exit in it ?
                                          Do you have an example ?
                                            @lmerckx said in Strange error in Dosbox:
                                            s**t I f you don't have a rpi3, it's not gonna be easy to find the issue ...
                                            I always use a dosbox.bat with all necessary instructions in it (mount for instance but no need for exit), I keep no command at all in dosbox.cfg (I always have one too)
                                            If you need, I can give you my dosbox.bat and dosbox.cfg for Epic Pinball
                                            figured as much, but I don't have any linux at home other than my recalbox ...
                                            Copyright ยฉ 2021 recalbox.com
