    Amiga with DragonRise Inc. Generic USB Joystick
    GamePad/GPIO/USB encoder
    amiga dragonrise inc generic usb
    4040
    • alpermis
      alpermis last edited by
      Amiga1200/Amiga600 does not work with my DragonRise INC. USB joystick. Start button on the joystick brings up the amiga config screen and I can see my Dragon USB joystick under Input tab selected as port1.
      All other systems work with my joystick. Only amiga ones act up.
      What I tried so far;
      1. Changed port 1 to my second joystick. (Same model/type arcade usb joystick)
      2. I tried Custom controls checkbox.
      Nothing helped.
      Interesting note: Start button and Hotkey botton works. Start button brings up amiga config screen and hotkey terminates the game. But joystick and other buttons does nothing.
      https://file.ac/kf_70Ayr0hA/
        voljega Banned @alpermis last edited by
        @alpermis yeh unfortunately there is a bug with dragonrise encoders and a few others in this version of the emulator amiberry, next one should be fine but next update will not be until several months
        • alpermis
          I am planning to use GPIO instead of DragonRise usb. Is amiberry works ok with GPIO drivers? Would be nice to know before I put all the effort for the cabling.
            @alpermis I don't know, try opening a specific thread asking for this question ?
            • plaetzchen79
              plaetzchen79 last edited by
              Hi,
              any news on this issue?
              My controllers dont work 😞
              I think Amiberry has fixed this issue
              in V 2.2.1
              https://github.com/midwan/amiberry/wiki/Version-history
              Thx, Greetings!
                voljega Banned @plaetzchen79 last edited by
                @plaetzchen79 The version of amiberry included in recalbox still says the same for now, so there won't be any change until we upgrade it and this will require a lot of rework and testing.
                • Dante 0
                  Dante 0 last edited by
                  Oh that´s terrible... I have the same problem.
                  • plaetzchen79
                    plaetzchen79 last edited by plaetzchen79
                    I think someone found a solution mentioned here:
                    https://github.com/midwan/amiberry/issues/114
                    Is this a possible (temporaly) workaround ?
                    Looks complicated though
                      @plaetzchen79 not for recalbox.
                      plaetzchen79 1 Reply Last reply Reply Quote 0
                      • plaetzchen79
                        plaetzchen79 @voljega last edited by
                        @voljega what a pity
                        But thank you for quick answers!
