    autostart
    Media-center/Dualboot
    autostart
    3127
    • Edvis
      Edvis last edited by
      hello, how do I add the file I need to autostart when I turn on kodi?
      • patriccote
        patriccote last edited by
        @Edvis directly from the GUI of Recalbox, by pressing Start on your controller, you can go in the different menu and tell Recalbox to start Kodi at startup without having to "add a file".
        patriccote
        Edvis 1 Reply Last reply Reply Quote 0
        • Edvis
          Edvis @patriccote last edited by
          @patriccote
          No.I need the server part of the acestream to install, and its autostart.sh file added to the autostart
            Substring @Edvis last edited by
            @edvis depends on what this file does. And i'm pretty sure it will fail doing its job on recalbox
            Edvis 3 Replies Last reply Reply Quote 0
            • Edvis
              Edvis @Substring last edited by
              @substring This is the server for addon acestream, thanks to it it is possible to view the serials from the site lostfilm.tv
              in retropie I understand how to configure and in the recalbox I can not
              • Edvis
                @substring
                Can I install midnight commander in recalbox?
                • Edvis
                  @substring in the retropie, to add the file to autostart, you need to put the data into the rc.local file. can in recalbox too there is such file?
                    @edvis add ~/custom.sh where you start your bash file.
                    • Edvis
                      @substring Thank you
