    Amiga 1200 WHDLoad
    Emulatoren Arcade/PC/Konsole
    amiga 1200 whdload
    3366
    • Einklinker
      Einklinker last edited by
      Hallo,
      würde gerne Amiga 1200 mit WHDLoad benutzen aber hab nicht so die Ahnung.
      Habe die Spiele und muss ich den WHDLoad oder tinylauncher auf der recalbox noch installieren?
      Habe die neuste Version und Amiga 500/600 läuft ohne Probleme.
      Danke im Voraus.
        voljega Banned @Einklinker last edited by
        @einklinker https://github.com/recalbox/recalbox-os/wiki/Amiga-on-Recalbox-(EN)
        Einklinker 1 Reply Last reply Reply Quote 0
        • Einklinker
          Einklinker @voljega last edited by
          @voljega thx but i‘ve Seen before.
          I explain: I have a WHD Game in a zip folder and i take the folder inside the zip without the .info file to my rom library and create additionally a folder With the same name with ending .uae.
          When I starting the game, will be back in 2-3 sec. to my game list. What I make wrong? Adf games are working.
            @einklinker said in Amiga 1200 WHDLoad:
            nobody said to do that, you're supposed to create an uae file not a folder.
            • Einklinker
              Ah sorry, but how I create an empty uae file?
                @einklinker you just create a file and rename it
                • Einklinker
                  Sorry that was to easy, I imagined it harder.
                  It worked, thx 4 help.
