    08.02.19 e configurazione amiga
    Italiano
    08.02.19 configurazione amiga
    9
    62
    24449
    • gkralicek2
      gkralicek2 @zolive59 last edited by gkralicek2
      @zolive59 I just tested on my CRT TV in both 60 Hz and 50 Hz and i don't see much of a difference in the execution of scrollings (honnestly). I tried with great Giana sisters using the scrolling title and what i get at 60 Hz is similar to what is shown in the video @50 Hz you published a bit above. You can have a look here if you wish : https://youtu.be/cxaTxzuW5eA (if you put side by side both of the videos and play them at 720p, you'll see there is no obvious difference). Neither your video @50 or mine @60 give a "butter smooth"result anyway (which is somewhat normal considering the fact youtube encoding alters the output result) but all in all it's pretty decent.
      I really think the end result dépends on the TV or Monitor used and the quality of their electronic components (upconverters, up/down samplers, etc...). Some of them will display s**tty results @60Hz, some other @50Hz. It seems really difficult to define a constant truth valid for all the situations. One has to try and choose what gives the best results. If some get better monitor response out from a 50 Hz signal, that's ok, if others prefer what they see at 60Hz, let it be this way :=)
        Substring @voljega last edited by
        @voljega yes it is
        100.3k
