    Amiga Issues on latest build
    amiga latest build
    9497
    • roman126
      roman126 last edited by
      trying to get Amiga WHDL to run, unzipped the WHDL Game Folder to the Amiga Roms Folder, also placed UAE file with the same filename.uae, all Kickstart BIOS files present and correct, i goto run the game and black screen / crash. Tried with a few different WHDL Games and UAE Files with the same end result. Anything that I am doing wrong?
        Substring @roman126 last edited by
        @roman126 dunno, start a game, let it crash, and once back in ES, make a support archive
        • roman126
          thanks for the advice........does this help?
          /recalbox/share/roms/amiga600$ /recalbox/scripts/recalbox-support.sh
          /recalbox/scripts/recalbox-support.sh: line 43: lsmod: command not found
          /recalbox/scripts/recalbox-support.sh: line 50: ifconfig: command not found
          lspci: /sys/bus/pci/devices: No such file or directory
          /recalbox/scripts/recalbox-support.sh: line 53: aplay: command not found
          /recalbox/scripts/recalbox-support.sh: line 54: glxinfo: command not found
          /recalbox/scripts/recalbox-support.sh: line 55: xrandr: command not found
          /recalbox/share/saves/recalbox-support-20180210211919.tar.gz
            voljega Banned @roman126 last edited by
            @roman126 you have to upload the generated file on zippyshare or something
            • roman126
              Dohh.. sorry 🙂
              Support file here....
              http://www93.zippyshare.com/v/KQCrSMpx/file.html
                @roman126 well the log files in there are empty .... does the game go back to ES after a black screen or do you have just a black screen and nothing without returning to ES ?
                • roman126
                  Just a black screen crash, have to power down to get back to ES
                    @roman126 hmmm that doesn't sound good.... did you try with several games ?
                    • roman126
                      I’m gonna try again with some more and will report back, thanks for your help guys
                        @roman126 also are you sure the MD5 of your bios are ok ? if not it can lead to trouble
                        • roman126
                          roman126 last edited by roman126
                          just tried a fresh download / install of Recalbox, transferred & checked all required BIOS / Kickstart Roms, kick13,kick20 & kick31, all MD5 checked in Recalbox Manager, transfered another couple of WHDL Games and associated UAE files to Roms / Amiga Folder, refreshed gameslist, run a game and black screen again.
                          One thing I did find out that its not actually a crash as I first thought, using recalbox manager on my laptop I can Restart ES.
                          So I`m stumped!
                            @roman126 start a game, and once you're back in ES, make a support archive please
                            roman126 1 Reply Last reply Reply Quote 0
                            • roman126
                              here goes....
                              http://www45.zippyshare.com/v/R36acHIt/file.html
                              • roman126
                                roman126 @Substring last edited by
                                @substring here goes....
                                Thanks for your assistance:-)
                                  @roman126 jusu too much ads on zoppyshare, i can't even reach the download. Why don't you just paste thelink that the webmanager made for you ? http://recalbox/help
                                    voljega Banned @Substring last edited by voljega
                                    @substring with uBlock Origin you don't see any ad 😉
                                    @roman126 I don't understand but your ES logs are again completely empty ....
                                      Substring @voljega last edited by
                                      @voljega no ads after a few clicks, but no file either
                                        @substring had no problem dowloading it but there is absolutely nothing, nada, walou in es_launch_stderr.log and es_launch_stdout.log, how is that possible ?
                                        • roman126
                                          roman126 @voljega last edited by roman126
                                          @voljega @Substring Going to try again, just a question regarding the WHDL Folders, I`m not using unzipped LHA WHDLfolders, but WHDL folders that contain a slave file, and data folder, etc. I assume this is the correct 'type' of WHDL folder?
                                          Filenames are crucial i`m guessing for these to work, if the UAE file and the WHDL folder name are the same is that O.K, or do the contents of the WHDL folder have to have the same name?
                                          For example
                                          Apidya.uae - Folder name Apidya
                                          But in the Apidya folder the slave file is called ApidyaKaiko.slave
                                          Should the UAE, Folder & the contents have the same filename? They didnt have to in Retropie as long as the folder name and UAE were the same, but who wants to use Retropie 🙂
                                            @roman126 no only folder and uae file needs to be the same name 😉
                                            when you launch a game do you have at least access to the GUI ? (pressing start on your controller or F12 on keyboard)
