    Amiga Support
    Emulator Arcade/PC/Console
    amiga
    2151
    • alpermis
      alpermis last edited by
      First of all amiga support is awesome. Thank you for all the effort.
      But I have a little problem. First of all config files seems kept in tmp folder and I could not find to change that location. And If I make any changes in settings and save, default config loads anyways.
      An the last problem; I am using PS4 controller as joystick. It is working, but not the little joystick only direction buttons.
      Regards,
        voljega Banned @alpermis last edited by
        @alpermis yeah there is a little bug with ps3 controller, joystick isn't working right in current emulator version, it will be corrected in the future.
        For custom conf it's not possible for ADF for now, what do you want to do exactly ?
        MMorbius vanYth 2 Replies Last reply Reply Quote 0
        • MMorbius
          MMorbius @voljega last edited by
          @voljega
          Hi there,
          well, then I link myself in.
          I have the same problem. I want to hide the status bar in the lower right corner.
          I can do it in the menu, but like alpermis said, even if i save, at the next game i start, the status bar is back.
            voljega Banned @MMorbius last edited by
            @mmorbius you must look into configgen generation for amiga.
            Or search through the forum I gave the solution to that several time already
            • vanYth
              vanYth @voljega last edited by
              @voljega
              @voljega said in Amiga Support:
              How sad. There are some games needing Kickstart 1.3 or those games using two or more disks could be configured using the second/third/fourth virtual drive with a config file...
              voljega 1 Reply Last reply Reply Quote -1
                voljega Banned @vanYth last edited by voljega
                @vanyth did you even bother to try the amiga emulation on recalbox ? or reading associated documentation ?
                101.4k
