    Problem with moonlight
    moonlight
    7
    41
    23523
    • jor2404
      jor2404 last edited by jor2404
      Hi I had monlight working perfectly until without intention I updated Geforce Experience.
      I have downloaded again to 2.11.4 version but now it doesn't work.
      I run the command /Moonlight.sh clean and then tried to pair again but it wasn't possible I also delete the folder keydir from moonlight.
      What I am doing wrong?
      • yanovsk
        yanovsk last edited by yanovsk
        Hello,
        I've had lots of problems to pair moonlight.
        Here's my solution : https://forum.recalbox.com/topic/12292/moonlight-ma-solution
        GFE 3.10.0.95 works with Recalbox 171202
        The stream (wifi) is stable from Steam client with 720p quality.
        But sometimes I have to launch 2 times Moonlight which comme back to emulation station.
        Good luck !
        RPI4 avec Xin-mo 2P/8btn
        RPI3 avec 8BITDO SF30 Pro, bouffée par mon chien
        RPI2 ...boot Kodi sur TV salon !
        • Jovanny Paulin
          Jovanny Paulin last edited by
          What worked for me:
          1.- Unistall the actual GFE
          2.-download version GFE 3.10.0.95 link
          3.- Go to C:\Windows\System32\drivers\etc and edit (with admin privileges) the file hosts
          just add at the end the line "127.0.0.1 services.gfe.nvidia.com #Block GFE Updates" whitout quotes this should block all updates redirecting the program to a non-exist server
          4.- install the GFE 3.10.0.95
          5.- once installed its time to do all the pair thing on recalbox
          Voila
          Jovanny Paulin 1 Reply Last reply Reply Quote 0
          • Jovanny Paulin
            Jovanny Paulin @Jovanny Paulin last edited by
            @jovanny-paulin I need to block these too from host file
            127.0.0.1 international-gfe.download.nvidia.com
            127.0.0.1 192.229.210.202
            127.0.0.1 192.229.162.216
            127.0.0.1 ota-downloads.nvidia.com
            • jor2404
              @jovanny-paulin said in Problem with moonlight:
              What worked for me:
              Voila
              You are right I didn´t read your answer until now but I was making tests yesterday and I realize that the solutio is to block
              ota-downloads.nvidia.com as you say. Finally we have a solution 🙂
              @Substring maybe it could be a good idea to make a reference for this solution in recalbox documentation to warranty that everybody can still enjoy moonlight in spite of the new Geforce Experience version.
              If yo have problems pairing after this go to GFE end delete all shield devices, the run ./Moonlight.sh clean and after this pair again
              jor2404 1 Reply Last reply Reply Quote 0
              • jor2404
                jor2404 @jor2404 last edited by
                @jor2404 said in Problem with moonlight:
                What worked for me:
                Voila
                Now my problem is that games are not launched from moonlight, before this process with GFE 3.10.0.95 I run the games perfectly. Now I only see again a black screen. Anyone knows how to solve this?
                Jiří Masopust 1 Reply Last reply Reply Quote 0
                • jor2404
                  @Substring I have tried with GFE versions that previosuly works ok but now I still can´t launch games from moonlight.
                  Pairing process seems to work correctly but in es_launch_stderr.log I get:
                  You must pair with the PC first
                  And in es_launch_stdout.log:
                  /usr/bin/moonlight stream -config /recalbox/share/system/configs/moonlight/moonlight.conf -mapping /recalbox/share/system/configs/moonlight/mappingP2.conf -input /dev/input/event2 -mapping /recalbox/share/system/configs/moonlight/mappingP1.conf -input /dev/input/event3 -app FIFA 18
                  Moonlight Embedded 2.2.2 (SDL;EMBEDDED;CEC;PI)
                  Searching for server...
                  Connect to 192.168.1.103...
                  NVIDIA GeForce GTX 750, GFE 3.0.7.34 (protocol version 7)
                  Any clue to solve my problem? Could have I deleted some necessary files into \recalbox\share\system\configs\moonlight?
                    Substring @jor2404 last edited by
                    @jor2404 run the Moonlight script with the clean parameter first
                    • jor2404
                      jor2404 @Substring last edited by
                      @substring I have run ./Moonlight.sh clean before run ./Moonlight.sh pair. Then it pairs correctly but I can´t launch the games and in es_launch_stderr.log I still get:
                        @jor2404 have you edited the moonlight.conf to set a IP ?
                        • jor2404
                          @substring In moonlight.conf I edited this line at the top of the file:
                          address = 192.168.1.103
                          That ip is from my stream pc
                            @jor2404 am i rught to believe you don't have only one GFE PC ?
                            • Jiří Masopust
                              Jiří Masopust @jor2404 last edited by Jiří Masopust
                              @jor2404 Today I was also trying to solve the blackscreen problem. I did all steps described in this forum but without success. I use it for running Steam and after selecting Moonlight the Steam was executed on my PC automatically but at my Raspberry there was only black screen again.
                              Then I started following. I downloaded and installed latest fresh Recalbox image and did the Moonlight pairing with my computer. Everything was working at first try and games were running. But I do not wanted to configure whole Recalbox and Kodi again for the new SD card. So I made a backup of all files in /share/system/configs/recalbox/moonlight. Then I put back my old SD card deleted all files in share/system/configs/recalbox/moonlight and copied files from working card backup. After this step my old SD card started working and Moonlight is running games correctly.
                              One hint: When I tried to delete the files from card if was not possible using the shared folder. It was necessary to stop the emulation station and login as root directly at RPi computer.
                              • Gimpi
                                Gimpi last edited by
                                i always stuck on the pair thing...
                                the last message i got is
                                "Searching for server..."
                                and then nothing happens and i do all the things in this thread above .. so i think dont know what to do
                                  Substring @Gimpi last edited by
                                  @gimpi it means it can't find a GFE host in your network
                                  Gimpi 1 Reply Last reply Reply Quote 1
                                  • Gimpi
                                    Gimpi @Substring last edited by
                                    @substring yeah but What Can i do GFE is running and the stream Option is enabled
                                    I tried to put the IP into the moonlight config and Not i have only one PC running with gfe
                                    I tried with ethernet and WiFi always stuck on this point did i miss something?
                                      @gimpi are your pi and GFE PC on the same subnetwork ? have you tried moonlight on your phone and see if it works ? Have you ever successfully streamed your games ? Is your GPU compatible with streaming ?
                                      • Gimpi
                                        @substring hmmm how i Can See if There is in the same sub Network i Think so because i have only one Network here
                                        Dont try it with my Phone i will try this later
                                        Yes my gpu is Ready to stream gtx970
                                        I Just streamed via steam from my PC to my Windows Tablet
                                          @gimpi can you reach recalbox through network shares ? can you ping your PC from Recalbox ?
                                          • Gimpi
                                            @substring if i put the IP from recalbox into my Chrome Browser have access to All the Things i need
                                            I dont See the Box in the Windows Explorer / Network view where i Can See the Fritz Box
                                            The Ping Thing is Just Ping IP into the Controll Pannel (f4)? I will try
