    XBOX360 Wireless Controllers not working normally after update
    GamePad/GPIO/USB encoder
    xbox360 wireless normally update
    • MarcWilmots
      MarcWilmots last edited by MarcWilmots
      Since the Update my wireless XBOX360 Controllers are not working normally.
      I cannot use the sticks or cross to go left, right, up or down.
      Only two buttons seem to have an effect.
      A clean installation hasn't helped.
      Before the update i was able to activate an xbox driver. This option seems to be gone now.
      Does anyone have an idea how to fix this?
      (The green light on the XBOX360 controller receiver is on. The controllers are connected. System is a Raspberry Pi 3)
        map your controller in emulationstation options menu
        MarcWilmots 1 Reply Last reply Reply Quote 0
        • MarcWilmots
          MarcWilmots @rockaddicted last edited by
          @rockaddicted That helped. Thank you
          • elvizius
            elvizius last edited by
            Excuse me but, from the update 17 the configuration for the gamepad xbox 360 is disabled. I changed the configuration of the gamepad ps3 to 0, but I can not activate the gamepad 360. I show you the configuration of my recallbox.conf:
            -------------- D - Controllers -----------------
            Enable support for standard bluetooth controllers
            Please enable only one of these
            -------------- D1 - PS3 Controllers ------------
            controllers.ps3.enabled=0
            Choose a driver between bluez, official and shanwan
            bluez -> bluez 5 + kernel drivers, support official and shanwan sisaxis
            official -> sixad drivers, support official and gasia sisaxis
            shanwan -> shanwan drivers, support official and shanwan sisaxis
            controllers.ps3.driver=bluez
            ------------ D2 - GPIO Controllers ------------
            GPIO Controllers
            enable controllers on GPIO with mk_arcarde_joystick_rpi (0,1)
            controllers.gpio.enabled=0
            mk_gpio arguments, map=1 for one controller, map=1,2 for 2 (map=1,map=1,2)
            controllers.gpio.args=map=1,2
            Look?Where is the config for the xbox 360?
