    Pi switch : what do you think ?
    Community projects
    switch
    • ChadDaddy
      ChadDaddy last edited by
      Hello,
      I'm planning on making a Nintendo switch clone with a raspberry pi 3.
      I found this on the forum but it's for raspberry zero. I assume that the connection to the raspberry is different but is the rest good for the rasp 3 ?
      https://i.imgur.com/74mlicv.png
      Also, I found a lot of stuff. Can you tell me if that's good?
      • a simple little on/off switch
      • the adafruit powerboost 1000c
      • this sound card + jack to disassemble a little
      • 2 gameboy color/advance speakers (idk :oops: )
      • a gameboy color volume wheel
      • this micro USB charging port
      • his USB hub to disassemble (I was told it work on raspberry zero)
      • This stereo amp
      • this controller who I want to disasemble to connect it with cables to the raspberry à démonter pour la raccorder avec des câbles au raspberry
      • this screen
      • this controller board
      • a battery (I'll take according to the place I have left)
      • a box printed with a 3D printer
      I'm not sure at all for the screen and the controller board if they gonna work with the rasp....
      Also, I wonder if I Can use two different controllers to play without redoing the keys each time. The one I said above for portable mode and an ajouter bluetooth one for TV mode.
      What do you think ?
      • ChadDaddy
        No one wants to help me...
        • tikiandskull
          tikiandskull last edited by
          you can take a look here, it's the same kind of project but on a WII U
          link text
