    Quadrados amarelos no inferior da tela
    Emulador Arcade/PC/Consolas
    saveload save state erro
    • LeoPreissler
      LeoPreissler last edited by
      Atualizei a versão do meu Recalbox que uso em um raspberry pi3 para a mais recente (17.12.02) e agora quando abro um jogo ou uso as funções de save e load aparecem uns quadrados amarelos na base da tela, aonde costumava aparecer informações sobre os comandos. Tem alguma configuração que posso fazer para corrigir esse erro?
      • kelv
        kelv last edited by
        Youo can check the solution here https://forum.recalbox.com/topic/7481/yellow-writing-when-loading-rom/16
        If you see yellow squares at the bottom then this means that Retroarch isn't loading a font.
        You likely don't need to delete anything, just navigate to your Retroarch Config here: /recalbox/share/system/configs/retroarch/retroarchcustom.cfg
        Then add this line to the Config: video_font_path = /storage/assets/xmb/retroactive/font.ttf
        Raspberry Pi model: RPi 3b+
        Recalbox build : 7.0.1 DragonBlaze
        Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
        Overclocked: 1485 MHZ
        Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
        LeoPreissler 1 Reply Last reply Reply Quote 1
        • LeoPreissler
          LeoPreissler @kelv last edited by
          @kelv thanks man
