    Speedlink torid xbox 360 controller connection problems
    GamePad/GPIO/USB encoder
    speedlink torid xbox 360 connection
    • Hans Fleischmann
      Hans Fleischmann last edited by Hans Fleischmann
      Hello,
      i have some problems with my speedlink torid controller and recalbox.
      First, the controller is not detected at system start. I have to remove the usb dongle and plug it in again. Then it works for a short time. But afterwards, the connection to the controller breaks suddenly while playing. After i remove and connect it sometimes to different usb ports to my Raspberry Pi 3, it is detected again.
      I have deactivated the PS3 Controllers in the recalbox.conf, you can see it here:
      https://file.ac/LyXUuuS-C2w/
      Any thoughts about this problem? How can i make my controller working correctly?
      Thank you!
      I have deactivated all other control devices and then i have activated the xbox controller:
      controllers.xboxdrv.enabled=1
      controllers.xboxdrv.nbcontrols=1
      100.7k
