    Solved Command dificulties...
    dificulties
    • vale075
      vale075 last edited by
      I am new to linux and I am trying to disable the loopback settings from alsamixer at each start of the system but I cant figure what is the command line to do this.
      All I have been able to find is :
      • amixer set 'Loopback Mixing' Disabled
      But I doesn't works...
      I am sure I am not putting the right command, could someone help me ?
      Infos :
      Command description
      amixer scontents :
      Simple mixer control 'Loopback Mixing',0
      Capabilities: enum
      Items: 'Disabled' 'Enabled'
      Item0: 'Disabled'
      Thank you in advance !
        Substring @vale075 last edited by
        @vale075 once it disabled in alsamixer, the settings are saved at shutdown and applied at boot. Which recalbox version do you have ?
        • vale075
          I have a 64 pc version and I am just not finding how to write the command because trust me I know what I am doing.
          The alsamixer settings won't save that is why I want to do a startup script that will change the loopback setting but I can't figure how to write the command..
          • vale075
            Oups...
            I just found out that the command I wrote down actually work...
              @vale075 I personnaly prefer going full steam ahead with TERM=xterm alsamixer and set everything from there
              100.8k
