    Unsolved Big, loud noise when Recalbox boots on PC
    pcx64 recalbox4.1 4.1 boot sound
    • vale075
      vale075 last edited by
      When I start recalbox 4.1 on my PC, after some time during the booting process, it start to make a really loud and painfull sound.
      I dont think it comes from the fans...
      The sound starts when the "Starting lirc : OK" appears.
      Screenshot
      Here is a video of the console
      Thank you all in advance !
        Hello ssh -> alsamixer -> disable loopback
        vale075 2 Replies Last reply Reply Quote 1
        • vale075
          vale075 @rockaddicted last edited by
          @rockaddicted
          Thank you very much !
          You solved my problem ! ( - ;
          • vale075
            @rockaddicted
            I am now having another trouble...
            The aslamixer settings wont save :
            SSH console
            Is there a solution ?
