    Roms from multiple sources?
    roms multiple sources
    • 32vk
      32vk last edited by
      At the moment I've installed some roms on a 32gb sd card thats running the system. I also have 2x 256gb usb sticks that have all the rest of the roms, but I can't seem to get them to select all at the same time.
      As an example if I change the settings to read from anyexternal it will only read and display roms from one disk/sd card at a time.
      Is this normal or a fault with my setup? Is there any way to get it to show them all?
      Thanks
      • abunille
        abunille @32vk last edited by
        @32vk
        Hi,
        this is normal, you can't get working both usb sticks at the same time.
        I don't know any way to do this.
