    Error saving shader preset
    • Dragu
      Dragu Banned last edited by
      I found nothing on this, but perhaps I am also a little bit blind today.
      I wanted to change in Retroarch (Hotkey+B) Quickmenu-Shaders sur SNES (Mario World). I can test it in the running game, but if I want to save, this bit.. tells me : "Error saving shader preset" What can be the problem ?
      • Dragu
        In retroarchcustom.cfg is following line
        video_shader = "/recalbox/share/shaders/custom/mysnesshader.gplsp"
        But the folder /recalbox/share/shaders/ is not existing.
        • Dragu
          I suppose because the chosed shader is in share_init, but not in the ES provided Set ?
          Ok, I put this line in recalbox.conf, seems to work.
          snes.shaders=/recalbox/share_init/shaders/shaders_glsl/scalehq/2xScaleHQ.glslp
