    Definitive PSX guide
    Emulator Arcade/PC/Console
    definitive guide psx playstation
    • Skiuv
      Skiuv last edited by Skiuv
      Multi-disk
      First of all we will see the different possibilities offered by Recalbox to swap disks.
      PSP mode
      Package all the disks in a single file eboot.pbp. You can change disc from the Retroarch menu.
      Advantages:
      • Controller shortcuts can be used to swap disk.
      Disadvantages:
      • The .sbi files can not be used in multi-disk games.
      • Can not change to a patched disk (with LibCrypt protection fix).
      • It takes time to change all multi-disk games to eboot.pbp.
      PCSX-reARMed mode
      The following disk is searched from the Retroarch menu.
      Advantages:
      • Your games are in .bin/.cue format.
      Disadvantages:
      • This does not work currently.
      • It's ugly and slow.
      • Save files are not shared among the disks.
      • Controller shortcuts can't be used to swap disk.
      Therefore, games with LibCrypt protection and multi-disk are a pain in this two modes.
      Definitive way
      For this mode it is necessary to add the .m3u extension to the PSX part in "/recalbox/share_init/system/.emulationstation/es_systems.cfg" (please developers, add this in the next version, thanks). For this, you can use a virtual machine with Ubuntu (for example) and connect the sd to modify the file. The modified line would look something like this:
      <extension>.m3u .img .IMG .pbp .PBP .bin .BIN .cue .CUE .iso .ISO</extension>
      Once this is done, you only need to create an .m3u file for each multi-disk game. This file will contain the names of the .cue files. For example:
      m3u
      The final aspect would be this:
      psx folder
      As you can see, there are .cue/.bin/.sbi per disk and a .m3u per multi-disk game.
      Advantages:
      • The .sbi files can be used.
      Disadvantages:
      • You have to change es_systems.cfg file (only once).
      • You have to hide the .cue files in Recalbox menu.
      Set controller shortcuts for disk swapping
      • In game, go to Retroarch menu (Hotkey+B).
      • list itemPress A to go to Main Menu.
      • list itemGo to Settings > Input > Input Hotkey binds.
      • Set Disk eject toggle, Disk next and Disk prev with your favorite keys.
      • Example: Disk eject toggle (right-analog up), Disk next (right-analog right) and Disk prev (right-analog left).
      • Now in game you can press Hotkey+"key" to eject disk, swap disk and insert disk (and reset game if it's necessary).
      Glossary
      • .ape: compressed file for .wav file.
      • .bin: game data and music tracks.
      • .ccd/.img/.sub: CloneCD files. You have to transform in .cue/.bin (with IsoBuster for example).
      • .cue: file where the disc tracks are defined. One per .bin.
      • .ecm: compressed file for .bin file.
      • .pbp: PSP file for PSX games.
      • .ppf: patch file for games with LibCrypt protection.
      • .sbi: file that contains the protection information and that are needed to run protected games in emulators.
      • .wav: music track file. You have to rename to .bin.
      Interesting links
      • ECM-APE Guide
      • PSX game list
      • .sbi files
      • .cue maker
      To be continued...
      1 Reply Last reply Reply Quote 3
        voljega Banned last edited by
        good summary, you might want to do a wiki page once it's finished.
        About the m3u, does it simplify in any way the opening of the lid and changing the disc compared to using using a pbp and doing that through retroarch ?
        Skiuv 1 Reply Last reply Reply Quote 0
        • Skiuv
          Skiuv @voljega last edited by
          @voljega said in Definitive PSX guide:
          Disc swapping is equal in both methods.
          • Skiuv
            Skiuv last edited by abunille
            Here is the wiki link with updated content: Guide.
            abunille 1 Reply Last reply Reply Quote 1
            • abunille
              abunille @Skiuv last edited by abunille
              @skiuv said in Definitive PSX guide:
              I have corrected your link above, how we wrote on IRC 😉
              Thank you for your work
