    Poweroff ps3 sixaxis
    GamePad/GPIO/USB encoder
    poweroff ps3 sixaxis
    • Damien DALY
      Damien DALY last edited by
      Hi,
      I would like to know if (and how) it is possible to poweroff the PS3 sixaxis ? For example, I would like to make "long pauses" and avoid the pad to drain battery...
      Thanks.
      • Rivalus
        Rivalus last edited by
        Did you mean powering off the PS3 Controller? If it is, you can just press and hold PS button in the middle until all the light switch off.
